Question about Canon PIXMA MP150 All-In-One InkJet Printer
When I go printing it says it´s error. Can anyone help me?
Error J21 on taskalfa 180
try taking out the cassette and cleaning the pick up feed rollers with isopropyl alcohol. jam 21 is no paper pick up from cassette.
if this does not work my need new feed rollers or feed clutch
Mar 26, 2014 | Kyocera TASKalfa 180 Copier
I have a TE 2000 casio till, it is printing Error 180 on the receipt roll & on the display it will state the relevant header ie reg, x, y, calc but will have flashing dotted lines under the heading....
This is an RS-232 error. It means the machine is trying to communicate with another device. If you have a PC or other device connected to the port, make sure you do not power it up with the cash register turned on or you will often receive this error. If the error just happens during normal use with nothing plugged into the port, then it has a fault. Some models were affected by this. It will often lock the register up until turned off and left to cool. A dealer can repair this problem. ------------------------------------------------------
If anyone needs more information, the Casio TE-2000 manuals are here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Aug 25, 2011 | Casio Parts Cash Register PC Desktop
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
Doesn´t scan or print; error
The 5100 error on this printer can be caused by a bad/faulty Carriage Unit, or Timing **** Film, or Logic Board, or Carriage Motor. If your printer is blinking only 2 times then a pause then blinks again 2 times this is more then likely the issue. You will need to contact Canon and find a repair center near you to fix this issue.
1-800-828-4040
or
1-800-652-2666
Best of luck..
Have a Happy and Safe Holiday Season...
Dec 01, 2010 | Canon MP520 All-In-One InkJet Photo...
It wont print but it doesn´t report no errors, it just doesn´t print
data cable connection may be loose
fix it properly or
change the data cable
Aug 12, 2010 | HP DeskJet 710c InkJet Printer
Free service manual with code for kyocera TASKalfa 180
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email itechf2@gmail.com
Especially interisuet off hibernation.
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
Proxies
Try www.hidemyass.com. It's kinda' laggy, but it works ok sometimes.
Apr 20, 2010 | YouTube Videos
Code error -180
Check your USB cable.  I was getting the exact same error and I found out I was using an older USB 1.0 spec cable.  When I switched to a USB 2 cable it began working fine.
Todd
Oct 27, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
How do you print in draft quality Canon Pixma MP 180
go to your setup or print options box. go to color management page. should be a print setup box showing draft, regular print, dpi etc. check the draft print mode.
Sep 11, 2007 | Canon PIXMA MP180 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
15 people viewed this question
old marine
old marine
