Question about Boating
Water is getting into gear oil, lower end. I know what the problem is, I just want to know if I can do the work myself. I am a 58 year old drummer and I don''t have a lot of money. I phoned Klaus Marine, they told me it would cost 400.00 for them to fix. I can''t afford it. The kit for changing the seals is only 50 00. I wish I had a manual. My motor is a 9.9 evinrude. If you could help me I would really apreciate it. Thanks. Armando Borg.
    Top Expert:
  • 45,252 Answers
There is more than 1 way water can get in sad to say and with out a pressure test you might fix it and fix it and fix it again .400 sounds steep to me it might be shift rod seal or drive shaft seal or prop seal.or a combination of all three.check for fishline around prop shaft first .
Posted on Apr 25, 2010
Where is the gear box oil filler on 40 year old ? fiat tractor I have owned 30 years my husband died now trying to do maintenance
Hi Hazel:
Without the model number it's pretty hard for us to try to figure it out.
There are probably at least 3 sources where you can get qualified help on really short notice.
1) The nearest Fiat farm equipment dealer.
2) A local antique farm equipment association.
3) An old "Farm Boy" like myself who lives not too far away.
You have my best wishes.
I sincerely hope that all works out well for you.
Ted
Aug 27, 2015 | Fiat Cars & Trucks
How do i start an engine after it is submerged under water?
Drain lower end gear oil n look for sand in oil if only water just replace gear oil! Pull carburators out and clean and replace gaskets then pull all spark plugs out and spin engine at W.O.T.(wide open trotlte) also while turning engine spray oil (fog oil for winterize)to lube crank, rods,pistons and cylinders that way when first start is 1_3_2014_2_26_08_pm.png
Dec 19, 2013 | Boating
Oil coming out of were water goes in on leg of yamaha 15 horsepower outboard why is this so ???
If your water pump has failed it could be that your lower shaft gear oil is getting past and running out.
The water pump on those should be replaced yearly. They are a rubber wheel with fins on it. They dry out and weather rott wich leads to their failure.
Aug 23, 2013 | Boating
Chain not getting oil
Extremely difficult! If the oil pump or worm gear is defective it may be the most difficult saw to repair. This is the only saw I have seen with the oiler mounted behind the fly wheel.
Your basic model number is 600035. There are 11-, 21-, and 22- prefixes used with 600035s. There are also a ton of suffixes with the 600035s. I think the suffix is on your saw immediately after the basic model number somewhere (usually on bottom of older Macs along with the serial number. The dash of the serial on older Macs is the prefix). I must defer to you to find your exact IPL, here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
I chose this one as an example "22-600035-58" for an IPL
http://www.ordertree.com/modelinfo/MCC/22-600035-58-Mac-3516-IPL-211229-01/139.22-600035-58-Mac-3516-IPL-211229-01.1.59.1.html
The "Powerhead Assembly" lists an oil pump (1) and a worm gear (10). These are the most common failure on most saws but Macs have many more hoses than most. There are oiler components on at least 2 different details. It appears the oil pump is on the starter side of the engine. and you may need to remove the fly wheel for access. I would examine every connection and perhaps try the "Kit Gear/Plunger Assembly" before trying to access the oil pump and gear.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
You can reply below with any questions. I hope you found this most helpful. Good Luck
Lou
If you opt to remove the fly wheel PLEASE reply to me first. I can probably save you a couple of headaches and may prevent component breakage.
Feb 01, 2010 | McCulloch Garden
My outboard motor is leaking white milky oil what is problem and how could i fix the problem myself??
I think you are getting water in the oil from somewhere. I assume you mean in the bottom end gear case ?
Nov 02, 2009 | RTO Oar Sockets
Water mixing with gear lube
i gher you mean tht water has got into your engine oil
thats not gear lube!
ok if it has then you have a whole lot of trouble!
it could be a cracked head or blown head gasket!
or the engine block has crackeeither way ! needs to get fixed so dont even try to start it as you could do a whole lot more damge!!
Get it looked at ASAP !!!!!
good luck
Cheers Rob.
Jul 20, 2009 | Ford F-150 Cars & Trucks
Shimano Altus gears
The old lubricant has gummed up. It needs a good cleaning and relubrication.
"STI shifters gum up after years of use. I've had good luck with this method and since it's nearly free it's probably worth a shot--
"Get a can of WD-40 or a similar light solvent/oil solution. Pull the brake lever back to the bar to partially expose the shifting mechanism and generously hose down the interior with your solvent. I mean really get it in there from all directions, using the little red spray tube if possible. Let it sit for a while and then drizzle in some light oil like Tri-Flo or similar. Then wipe down the exterior of the shifter with some Simple Green or other degreaser (to keep the overspray off your hands).
"I've rescued two sets of STI-type shifters with this method. Hope you get your problem solved one way or another, because new Dura-Ace sure ain't cheap."
source: http://www.bikeforums.net/archive/index.php/t-83743.html
Jun 25, 2009 | Mountain Shimano Altus Front Bike...
Shure beta 58
red pin 2
blue pin 3
case (ground lug) pin 1
Sep 11, 2008 | Shure Beta 58 Microphone
Boating Logo
139 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
