Question about Jacuzzi Bath Era BK37 959 White toilet bowl and tank
Need to adjust water level in the sistern to flush more in a laufen pro toilet
4 Suggested Answers
  • 308 Answers
SOURCE: super low water level in bowl decreases after flush refills
First, fyi, adjusting the knob? in the tank, or the fill level will not increase the amount of water in the bowl. The bowl fills to a certain point, and then as more water is added it starts to go over the built in trap, and down the drain. When you flush the toilet, all the water in the tank dumps into the bowl, and the existing water is pushed over the trap and down the drain. All of this being said it sounds like you may either have an internal crack, between the bowl and trap; you may have a crack that is draining under your toilet, (water spots?), or you have a more serious plumbing issue, improper venting, which is causing a vacuum, and pulling the water out. Hope this helps.
Posted on Jun 17, 2009
  • 349 Answers
SOURCE: The water level in the toilet bowl is too low.
Too little water in the toilet bowl to start with may be due to a lost or mis-connected fill tube that directs some water into the toilet tank standpipe (and thus into the bowl below), while the toilet tank is being re-filled. Check for that little tube.
Check the web site out below for more information on this topic.
http://www.inspectapedia.com/plumbing/Toilet_Slow_Flush.htm
Posted on May 29, 2010
packrat1948
  • 528 Answers
SOURCE: Toilet does not flush clean.
Welcome to the world of 1.6 gallon flush toilets. You have already done everything that can be done to help the problem and no you are not the only people having this problem. This is just the beast!
They have had this problem with these 1.6 flush toilets from the get go and have come out with power flush toilets to fix this but hold on to your wallet. There are some toilets out there that work better without the power flush made buy American Standard and Kohler but they will run you more then the Jacuzzi.
Sorry I wish there was a better answer to this.
Posted on Mar 23, 2011
I have a Kohler dual flush cartridge toilet and on small flush there isnt enough water being released to wash any paper away. We have two toilets like this and one flushes much more than the other. Can the...
not really as the flush time is set by the manufacturer in the design
what can be adjusted is the water level in the cistern
the more water , the longer the flush before the reset ( shut off)action is activated adjust that by the float screw ot water level adjust screw on the inlet stem
Feb 27, 2015 | Kohler Home
How do you adjust the clip so the water level increases?
You don't adjust the clip as it attaches to the pipe to automatic turn off the water at the right level, but your water may be set at to high a level that it overflows into the bowl. When that happens you can do 2 things to correct it: 1 at the wall where the cold water comes out to the toilet you can adjust it to slow the supply of water to a little less. 2. You can adjust the screw inside tank to tighten (turning screw one way) to adjust water level to shut off quicker or adjust tank screw the other way to fell take water up higher. Flush the toilet and observe the power of the flush. Allow the tank to fill until the water shuts off. Repeat the procedure to adjust the float and water level, if desired.
Apr 26, 2014 | Plumb Craft Waxman 7030700T Perfect Flush...
Adjust water level in in-wall Italian toilet cistern
It could be your flushing mechanism inside the tank that is letting the water in even after the flush. First flush and watch the bottom mechanism whether it blocks completely when water is full in the tank at set level and no more water flows.
Jul 27, 2013 | Home
After installing a new flush valve, the water level in the toilet bowl seems to be much lower than it was with the old flush valve. Is there any adjustment for the water level in the toilet bowl?
Yes,there it is!You can adjust your water level at the flush valve..You can see the ball there you need to adjust that so that the water level of your tank goes to your desired level.
Jul 29, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
Water leaking inside toilrt bowl
The flush megnisems rubber has parished.
Step1. open sistern and locate the flush meganisem, [shoold 90% of time be the gajet in middel]
Step2.unhook or unscrew all the handels conected to it,
Step3. turn the meganisem left, it wil pop out and at the bottom after you pop it out u see a black rubber that looks damaged, go to plumbing shop with the rubber and they will give u 1 ,its cheeep.
that should fix it.
plz rate my advice
Jul 12, 2010 | Eljer Toilet Onepiece Canterbury ...
Push valve for urinal adjustment. How do we
HI im Rossouw
Most sisterns with 2 buttons 1 for urin 2 for bouls have have a button on top of the sistern
Remove the lid of the sistern by thast lifting it or unscrew the head of the bottem
After the lid is of iets easy, wear the arms are of the indevidual bottons u mist thast find the 1 u want to be urin and turn it right for less water and left for more water
Plz rate mt advice thanx
Jul 12, 2010 | Mansfield Plumbing Products Mansfield...
The pump keeps running after flushing. Have to tap pump tank unit slightly to get it to shut off. Also from time of installation the water level in the bowl was and still is very low, any way to raise the...
hi keith
Bloues hear.
the water level in the boul is standerd to the manefactuer. the plumber cant help for that. if u put a level on ur toilet and iets level there is noting u can do about it.. the water that keeps on runing is ur seal rubber, its located at the bottem of ur flush meganusum. step 1.... tack off sistern aka pump. then step 2 ... unscrew your flush meganusem, will be the 1 in the middel of sistern. step 3 ... after unsrewing it u wil see there is a rubber. if the rubber looks fine then u must ajust ur flush meganisems arm or lubricate it. bt if rubber is misformed or teared ... u must go to a plumbing shop with the rubber. they will give u new 1 for cheap. and u can just reaplace it and esembel the sistern again
Jul 05, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Water seems to keep running very slowly, can't hear it, after it apparently stops after a flush. Eventually reaching the over flow tube in the tank. I have replaced the Toilet fill valve twice, The first...
Rossouw R. im a plumber.
Were the flexi hose go in to the toilet and conect up to velve thread tape. unscrew the flexi hose and then the plastick nut holding the velve on to the sistern.
put the new velve in and bobs ur uncel.
Its very easy, just look were the 2 seal rubbers are when u remove it, may be 1 rubber.
and the flout of the velve will be a cup or ball, thast ajast that tothe right water level, u will c were the flout or ball is on new velve there will be plastick with bumps un it [most commen] if not let me know bt around that area u should find somting to adjust the hight. sorry for spelling errors, im a plumber nt a english major lol
plz let me know if u get in a rut .that is realy the onley solution.
Jun 11, 2010 | RTO Fillpro Anti-Siphon Toilet Tank Fill...
Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Oct 24, 2009 | Kohler K-11470-0 White Wellworth Complete...
The self-lowering mechanism of my Laufen Pro toilet seat is broken, how can I fix it myself?
The pneumatic cylinder that controls the lowering probably needs to be serviced or replaced. Here is a link to the manufacturer website:
http://www.laufen.com/export/servlet/portal?codpage=productsresult&planguage=EN&ppais=EX&sesid=2302425382030&tipo=3&dlvalue=01A1&psgvalue=0008&dltxt=LAUFEN+PRO&psgtxt=WC-SEAT&radio_ch=&designline=01A1&productsg=0008
Mar 27, 2009 | Home
Jacuzzi Bath Era BK37 959 White toilet bowl and tank Logo
119 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
