Question about Toshiba 57HX83 57" Rear Projection HDTV-Ready Television
The screen is scratched and stained- I would like
I have a Toshiba 57HX83 rear projection tv. The screen is stained and scratched due to improper care. I would like to replace screen if possible.
  • 99 Answers
That is a good idea, but expensive.
if the screen is that bad, you may want to try with some commercial available polish for glass or plastic, like plast-x. you can get that in any auto parts store or your local walmart...
http://i93.photobucket.com/albums/l72/NoTwilight/temp/PlastX.jpg
Posted on Apr 23, 2010
Toshiba 57HX83 57 in. Rear Projection HDTV-Ready Television
With the back off you should be able to see the three large round lens this set should have---black cylinders with a glass lens--if real dirty they can cause picture to look darker and dull---I presume same with DVD player etc connected to rear input.
the lens point up so get dusty, the mirror points down at a angle and rarely needs cleaning.
Jun 01, 2012 | Toshiba 57HX83 57" Rear Projection...
Projection TV Screen is scratched/Speakers Don't work
u can buy new screen toshbia.com tv parts sears.com tv parts cost i have replace 1 before screen 300 bucks be very careful glass extremly thin thin will crack good luck
Aug 06, 2009 | Toshiba Televison & Video
Stain on samsung dlp projection tv screen
Sorry to hear that. It is damaged/scratched sound like
Nov 15, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Front screen
HOW TO CLEAN TV SCREEN;
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
51 inch projection screen tv
they are expensive try to buy a used one make sure it is not scratched
Aug 21, 2008 | Toshiba TZ50V51 50" Rear Projection...
HELP
when you say flash and went black do you meen after you turned it on it turned off does it do this every time you turn it on? or does it not come on at all
Jun 04, 2008 | Toshiba 57HX83 57" Rear Projection...
Toshiba 57H83 rear projction tv
are you talking about the plexiglass glare screen?...or something else?...
i was trying to find this out in your previous post about this set...
Jun 03, 2008 | Toshiba 57HX83 57" Rear Projection...
TELEVISION ON TOSHIBA LENS SCRATCHED
I would suggest that you clean the lenses and then apply some of the " As Seen on TV " lens scratch remover. I have used this product many times and it seems to work very well. If you have scratches on the screen. you may need to replace the screen as I have not found a good product to correct this problem. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Have a Great Presidents Day
Feb 13, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 57HX83 57" Rear Projection HDTV-Ready Television Logo
226 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
