Question about Kenmore Elite HE4 Electric Dryer
The dryer is not starting. I put in the load, pressed the cycle and start button - the lights go on, I hear a click, but then nothing happens.
  • lzlisser Apr 23, 2010
    110.85872401
  • lzlisser Apr 24, 2010
    Hi Joe - thanks for your response - it's strange because there is definitely power to the machine. Lights go on, it beeps, it locks. It does everything it usually does except start! How would we know if the heating fuse is burned out?
  • 15,935 Answers
Please reply with the exact model # of your unit.
Thanks!!
nc
Posted on Apr 23, 2010
  • 10,865 Answers
Hello Lz. If your dryer doesn't work at all, it could be because of problems with: Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Model FEQ1442ES0. I press the start button and all I hear is a click, nothing happens. What's wrong?
I appreciate your inquiry, Cody!
I see that your Frigidaire dryer is not operating after you hit the start button and it clicks. It is possible that your control panel or wiring harness could be causing this issue with your dryer. You may need to perform a reset on your dryer and you can do that by disconnecting power from your dryer for at least ten minutes. If this does not correct your issue I would seek assistance from a professional technician for a proper diagnosis and repair. I hope this information is helpful to you. -Matt
Jun 15, 2015 | Frigidaire Dryers
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
My whirlpool dryer wed9400sw2 is over a year old, but has stopped running. The last load was left damp. When I tried to restart the load, I pressed Power, Start. I hear a brief click from the start...
Hello Cdewlodge, we sincerely regret to hear this. If resetting the Dryer did not help then we would recommend scheduling service. If you would like for us to schedule service for you, please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
May 28, 2017 | Whirlpool GEW9250 Electric Dryer
The dryer will not operate. you can press the buttons , all the lights come on, but as soon as you press start you hear a clicking sound and then nothing happens. I seems the dryer is on but nothing is...
unplug dryer, remove back panel, look for a white part with 2 connectors on the blower housing and remove one, using a continuity or ohm meter put across the leads and if you hear no sound or see no reading in meter replace that part. is the thermal fuse. this is the most common problem for that failure.
Feb 12, 2011 | Whirlpool GGX9868J Gas Dryer
Dryer won't start
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 07, 2010 | KitchenAid KGYS700LQ Gas Dryer
Dryer doesn't start or blow air, how can I test parts to determine what needs replaced?
Hi there
Have a look around the motor for a yellow or silver tube like object with wires attached to one end .
if you see one of these "be very Carefull if you are not confident working around live electricity get a man in to do it"
start the dryer and then physically give the drum a push if it starts to spin what you require will be the start capacitor plenty of places online to buy spare from and easy to fit.
Regards Al "Alstech"
May 26, 2009 | GE Dryers
Whirlpool Duet washing machine will not start a cycle.
sounds as if its a door latch/lock issue, not recognizing the door closed will simply beep 3 times when the start button is depressed. try unplugging and replugging after 2 min.
Nov 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Diagnostics and Repair Details
Check your door switch first. You should hear a click when you push it in and light should turn off.. If it clicks it is probably ok. If you need to know how to replace it or if it is ok, please reply back with model number so I can give you more detailed directions in troubleshooting.
Oct 12, 2007 | Dryers
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
113 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
