Question about Pentair Minimax Ch 250,000 Btu Natural Gas Pool Heater Millivolt Ignition
Is there any difference in bottle gas heater and natural gas heater
  • 843 Answers
Yes. Bottle gas is propane, which is not natural gas. The gases behave a little differently, so the burners operate a little differently. Some are easily convertible, other not, but they are most definitely not interchangeable.
Posted on Apr 23, 2010
  • 634 Answers
By bottle i am assuming you mean propane. yes there is a difference , natural gas is mostly methane gas (ch4) a very small molecule, propane is (c3h8) a much larger molecule. so they require different gas nozzles and cannot run a unit on the other fuel, some can be converted to run other gas. generally natural gas units are cheaper to run, but cost more for installation as a gas line has to be run to the unit and benefit of not running out of fuel. hope this helps.
2 Suggested Answers
  • 128 Answers
SOURCE: Jet size differnce from natural gas to bottled
You will need more then new orifices to convert from natural gas to propane. The gas valve will also need to be replaced. Not a good idea converting heater.
Posted on Aug 23, 2009
How can I convert from natural gas to LPG bottled gas?
usually by installing a conversion kit .but if you have natural gas available it's always cheaper than propane
Apr 27, 2015 | Heating & Cooling
After running for a few minutes, my bottle top heaters start flaring and burning irregularly. The same thing happen when I hooked it up to another heater. Also when I turn the gas off it takes a lot of...
Are the propane tanks fitted with a pressure regulator?
The propane gas regulator is one of the most important parts of a propane gas system (or a compressed natural gas system as well).
The purpose of the regulator is to control the flow of gas and lower the pressure from the tank to the appliance(s) in the gas system.
The regulator not only acts as a control regarding the flow and distribution of propane (or CNS) but also as a safety barrier between the high pressure of the tank and the end use appliance(s).
Without it, you can cause serious damage to the appliance's gas valve and create a disaster- fire or explosion.
Nov 30, 2013 | Mr. Heater Model MH12TS - Single Tank-top...
Rinnai 551FT Hi I have just got this model
On the data plate on the heater it will say NG for nat gas or LP for bottle gas
Jun 05, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Just put in a new Caldera LPGas cooktop the flame is yellow and putting soot on pots how can I adjust air to correct this?
you stove may have jets for natural gas rather than bottled gas the calorific value of natural gas is different to propane and the jets are larger because of this. if using bottled gas then you will get yellow flame and soot because there is too much gas to burn properly check your installation manual for procedure to change the jets for each gas
Dec 19, 2010 | Stainless Caldera SSK-305 Steel Gas...
329H portable heater Can this be converted to a gas bottle fitting will it be ok what is the use age and how many watts of power to run the electronics etc
You need to convert the unit if you are changing from Natural gas to LPG. This involves getting a full conversion kit for your model and changing burner , gas pressures and electronic settings.
Power draw on high remains at 22Watts. Input is almost identical for either natural or LPG gas as you would expect but running costs depends on how much you pay for your LPG. For example in Australia we use 45kg bottles of LPG, they retails at about A$110 delivered. One of these would last about 170 hours running a 329 on high.About 2 litres of LPG per hour
Aug 26, 2010 | Heating & Cooling
Can this be used with propane does natural gas come bottle
Not sure if a propane conversion kit is available, their website is not cooperating tonight. heres the web address of their tech support: www.desatech.com
and no natural gas does not come in a bottle.
Sep 26, 2009 | Desa International GWN10 10,000BTU NatGas...
Jul 12, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Physical difference between natural & propane orfice
Merry Lynn, there will be no physical differences between Natural Gas heaters and Propane Gas heaters. Check the model number of the unit, it may have a N or P or LP printed at the end of it to distinguish which gas it uses. The plate that is attached to the heater should indicate the type of gas it uses.
DO NOT try to convert this heater to another gas.
Oct 16, 2007 | Reddy Heater RLP100 Portable Forced Air...
Pentair Minimax Ch 250,000 Btu Natural Gas Pool Heater Millivolt Ignition Logo
159 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
