Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
No suction - Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
  • no suction Jun 09, 2008
    Bissell 1697-M PowerSteamer Pro Upright Vacuum I have no suction in either the floor cleaning or using the hose for tool cleaning. The brushes and everything works, I just have absolutely no suction.
  • Anonymous Nov 20, 2008
    I'm also not getting any suction at all.
I finally got my steamvac F5914-900 suction to work after I read someone review about it on amazon. Here is what that person suggested for suction problem and to my surprise it worked.
1. Any time you aren't getting suction, the first thing to do is check the dirty water bin. I re-seated the thing about ten times this morning, trying to figure out why suction on the unit had ceased. (The dirty water tank was bone dry.) I was frustrated because I was absolutely sure everything was seated properly, but was still getting no suction.
Finally, I pushed on the lid from the _sides_ rather than the back or front while attaching it to the tank, and it seated a little bit differently. Suction was restored!
2. To clean out the suction area, pour some hot water on a tile floor (NOT wood) and **** it up. Repeat until everything is flowing smoothly. Sometimes, reduced or minimal suction is due to gnarly clogs. Again, though, if you're getting NO suction, the culprit is probably the dirty water bin's lid.
I hope this helps.
Posted on Apr 10, 2008
I've had my steam vac for three whole days now (Hoover).  Tried it out first thing on a area rug and it was great.  Today, I had no suction. I, being usually very organized, have been going nuts trying to find out where I put the instructions.  Apparently, I outwitted myself by putting them in such a memorable location I can't find them.  Anyway, I came here for help and followed the suggestion about re-seating the waste water tank. I tried it a couple of times without success, then tried seating it without the lid on...pushing it down hard then latching it. You should hear a 'snap' sound on at least one side. Then put the lid on...and it worked!  Also, on the front of the waste water tank there is a little baffle type thing that raises and lowers. Make sure that is pushed all the way down. Thanks for the solution and I hope everyone else with this problem will be successful.
Posted on Nov 23, 2008
My hoover steamvac will not pick up wet from the floor
Posted on Oct 26, 2008
Canister
Posted on May 31, 2008
Bissell proheat
does not **** up water
Posted on Apr 28, 2008
  • 126 Answers
What brand of vacuum and what style? Upright or canister? No suction is not enough info.
Posted on Mar 23, 2008
MY WRLD VAC BRAVO II DOES NOT HAVE SUCTION
There could be something clogging the suction path.
Nov 30, 2016 | Vacuums
Why does the suction stop after 10 minutes of use on my Dyson DC43?
Your vacuum may be overheating and shutting off the suction motor. Clean the cyclone assembly and the filters to see if they could be restricting the airflow.
Jun 18, 2014 | Dyson DC43 Purple Animal Bagless Upright...
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
Why would a Hoover Windtunnel have no suction?
It could be clogged at the head or throat, or you might have a hole in the hose. Unplug the hose; if you're getting suction where the hose plugs in then the problem is in the hose or the head. If you're not getting suction where the hose plugs in then the problem is in the body, probably the throat. If the problem is in the hose or head, detach the hose from the head and check for suction at the end of the hose. If there's not suction there, then you've got a clog or a hole. If there is suction there, then you've got a clog in then head.
May 20, 2014 | Vacuums
Riccar 8995 no suction
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
May 18, 2014 | Riccar Vacuums
How do I switch the vacuum from floor to accessory suction
It automatically switches over when you disconnect the hose from the power nozzle. No suction it getting to the power nozzle, so the suction is only through the attachments. If there is no suction through the hose, check for clogs in the hose and in the tank where the hose plugs in. Also, check the screen at the bottom of the tank. If there is a clog in the hose or tank, then there also will be no suction to the power nozzle.
Remove all clogs and you should get suction.
Dec 19, 2010 | Hoover U5721-900 WindTunnel Upright Vacuum
My DC17 suction hose doesn't have any suction occasionally.
check the seal on the filter is not broken,And check for any blockage at the bottom of the pickup pipe.
Nov 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The machine will not suction - it will spray and spin the brushes but will not suction - the power is going to the machine, but it will not suction.
Disconnect the suction hose. While running, check the suction port if it works, by putting a piece of paper. If the paper is taken in, then it is oK. Now, check the suction Hose for breaks or opening before the suction head. Breaks or opening breaks the suction power at the suction head. Loose connection between the suction pipe and the suction port also must be check as this will also cause the same
problem. You may need to replace the suction hose
to correct this problem,
Send us the e-mail and your vote if this solves your problem.
Sep 27, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Suction only works using the hand held mode, there is no suction when try to use on carpet mode,
There must be a clog in either the hose, dirt inland by the brush roll, or bad filters. If you have suction at the end of the hose, then look lower all the way to the brush roll.
Mar 25, 2008 | Vacuums
How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Jan 05, 2008 | Vacuums
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
933 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
