Question about Magic Chef CAV4000 Top Load Washer
Magic Chef W20HN3S Agitator Locks up during wash cycle.
All's quiet during lock up but electric type smell. turn off then on will sometimes start up again but usually hangs up soon. Spin seems to work ok but agitate on wash and rinse stops... Motor sounds good when wkg and belt looks good. Changed thrust brg ***'y about 4 yrs ago. I'm thinking transmission but how to prove it ??
5 Suggested Answers
Oceti
  • 51 Answers
SOURCE: Magic Chef CAV2005AWW makes a noise in agitate cycle
Sounds like a problem in the gear case. This would be a transmision replacement.
Posted on Dec 07, 2007
csmock132
  • 4669 Answers
SOURCE: Magic Chef Clothes washer model CAV2004AWW
Something locked up on the transmission then the drive belt broke. Put on a new belt and try a spin cycle, if it works but it won't agitate then the trans will need replaced.
Posted on Feb 28, 2009
Karthik316
  • 187 Answers
SOURCE: Magic Chef 20lbs hd won't agitate
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion.......
Posted on Jul 23, 2009
SOURCE: Tub does not spin but agitates
Sounds like the door switch is either loose or faulty. The door switch keeps the tub from spinning with door/lid open.
Charlie
Posted on Aug 21, 2009
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Will not spin on spin cycle
That is a single belt driven washer built by maytag. Check the lid switch for propah operation. If it is fine tip the washer back do an inspection of the beltthemobilian_2528.jpg
Check the pump for tightness sometimes they lock up or get something in em. If that is fine turn the main drive pulley and see if it releases the brake and lets the drum turn easily. One direction it locks the tub and agitates and the other direction is pumps out the water and spins.
Manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 01, 2011 | Magic Chef CAV2000 Top Load Washer
Gas smell during cooking cycle - Magic Chef oven
turn off the stove and call the gas company. They will come out for free and check things out. It's dangerous to be there when you're smelling gas. If you want to look into it yourself, use a soapy solution in a spray bottle and spray the gas valve and the gas line all the way from the valve to where it connects into the stove.
Oct 23, 2009 | Magic Chef 31000 Gas Kitchen Range
Charlie
Aug 21, 2009 | Washing Machines
Try these
  5. Test the motor
Jul 23, 2009 | Magic Chef CAV2000 Top Load Washer
I have a GE Profile Prodigy top load washing machine. Sometimes the spin cycle does not spin, sometimes it spins. It makes a clicking noise during gentle cycle
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
Only spin cycle
Check the lid switch, it only locks out the spin cycle.
eric
Jun 30, 2009 | Roper RAS8445KQ Top Load Washer
Feb 28, 2009 | Magic Chef CAV2004A Top Load Washer
Magic Chef CAV4000 Top Load Washer Logo
47 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
shaun taylor
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
