Question about Karcher 2500 PSI Pressure Washer
My Karcher 2400 PSI pressure washer is not starting after about 5 years. What type of spark plug and gap should I change the old out with and what kind of oil do you recommend. I don't think I have ever changed the oil but way less that 50 hours on the machine. Thanks
  • 92 Answers
SOURCE: trouble with Karcher Pressure washer
Dear Pgarciax,
It is important that you must have mentioned the model number of your Karcher. Just the same I can surely say that your machine's fault lies in the "SPILL VALVE"
When the gun is open and pressure is being produced, the spill valve is in a relaxed position. Also it has at the bottom a valve, which when pressure is produced it is closed. If this does not close due to dirt or corrosion, the pessure goes down. Now when you close the gun,pressure forces the spill valve down to close the electrical system. Now if the "o" rings of the spill valve are damaged, the machine will start going on and off while in stand-by. So if you know how to locate the Spill Valve, all one has to do is change it with a new one.
In some Karcher machines there are 2 spill valves. One regulates pressure and the other one is for switching off the machine when the gun is closed.
Low pressure could also be due to faulty suction or delivery valves. Most probably the suction valves.
But when saying that there are short interruptions while in stand by, I stick to the fact that the spill valve needs renewing.
Regards,
MG.
Posted on Nov 19, 2008
  • 2692 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
  • 3600 Answers
SOURCE: pressure washer that leaks oil through the air breather
Most likely your air filter is plugged or dirty, or the crank case vent valve needs to be cleaned.if it still does it check that the oil level is at the full mark, if overfilled it would cause the same problem.
Posted on Jun 22, 2009
deme-tri
  • 90 Answers
SOURCE: karcher 2400 psi washer- no pressure
if the water is flowing
the valves need to change
if no water pistons in pump need to change.
Posted on Aug 01, 2009
  • 3 Answers
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
Posted on Aug 04, 2009
How do you replace the pressure loading valves
if it is a karcher machine you will need to remove the pump, and the valves need to be removed with a set of valve pullers, karcher sell the special tool needed for this, you cant remove the inset types any other way but with the tool,
any questions just ask away
Feb 24, 2010 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Honda gc160 engine on 2500 psi washer, no spark?
new spark plug? flooding may have fouled the old one.
Jun 05, 2008 | Karcher 2500 PSI Pressure Washer
I have used my pressure washer for a while today cleaning some patio umbrellas. It just stopped and I thought I was out of gas so after adding gas, tried to restart. I could not pull the lever because it...
well did u shut water off to take pressure off if you did that it could possibly be a siezed motor you can take wd 40 and put plenty in spark plug hole and let sit over night and if you can pull it then change oil then try starting
Aug 26, 2009 | Alfred Karcher K2400HH 5 Hp 2.5 Gpm @ 2400...
Karcher 2400 psi washer- no pressure
Jul 22, 2009 | Karcher 2500 PSI Pressure Washer
I have a coleman powermate 2400. It started fine
Did you try a new spark plug. Old one may have fouled.
Jun 25, 2009 | Karcher 2500 PSI Pressure Washer
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
8HP troy-bilt will not start, this is my 1st time this year
Hi
Try changing the plug with a new one with the same heat range.Priming the engine(put some gas in the cilinder through the plug hole)and start the engine.
best regards savumihai71
Jan 28, 2009 | Karcher 2500 PSI Pressure Washer
Not enough pressure
Speed regulation on small engines is notriously fussy.
Check the linkage to the carburetor and look for a small, light spring.
If there are several holes for one end of it, you may have to try more than one to find the spring tension that lets the engine run steadier than it now does.
If not, then either replacing it or changing the length by shortening or lengthening it will probably be needed.
Aug 09, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
194 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
