Question about Sony PlayStation 3 40GB System
I cant start my ps3... HELP! Download ps3 update 3.30 install.... @ 70 % ever end... HELP!
  • 3 Answers
Had same problem for 1 month. I tore it competly down and cleaned everything. Cleaned off old thermal compound and put new on. Did NOT do a reflow. Put it all back together and it installed just fine. i have an 80gb. I also system restored it to basically brand new. and, updated it with a USB flash drive. Just download update from Playstation website to pc, and save on flash.
Posted on Apr 23, 2010
Cant update system so i can play blue rays
You can update your ps3 without going online on the ps3. Go to http://us.playstation.com/support/systemupdates/ps3/index.htm on your computer and download the newest update. Download it to a flash drive. Insert this into the USB port of your ps3. save it to your hard drive, and then update your system from the XBM. Also, newer games (little big planet 2) have the firmware on them so if you buy/rent them, you can install from the disc.
Feb 26, 2011 | Sony Playstation 3 (PS3) Console
I cant update my ps3 a error code 8002f994 keeps poppin up wats da problem
if you are facing trouble in installing updates you better download the repair guide for further information
regarding this ....... without knowing much about the ps3 you can easily repair with the help of repair guide ...........
thank you,
all the best............
Dec 10, 2010 | Sony Playstation 3 (PS3) Console
PS3 will not update and wireless does not work. I attempted to update my PS3 (the unit prompted me to update when I put in a game) it started to update, stopped, and now I can't update and games will not...
all the best.....................................
click here to Download
Dec 07, 2010 | Sony Playstation 3 (PS3) Console
Downloading ps3 update and I'm stuck on a error loop
hey mate!
i had the same problem as you have with a 40 gb model i bought with a ylod and fixed. after i assembled it i tried to update the firmware but it got stuck in a loop between 69 to 70 % and wouldn`t finish the install. after doing some research i found out the the error number that appeared (cant remember the number now) happned because some hardware wasn`t connected the way its suppose to,when 69% will indicate the blu ray drive,and indeed i noticed that the clip on the ribbon was broken . i had to use a piece of cardboard at first to shove it right to its place nice and tight and started the ps3 again , (failed again because my wifi antenna wasnt connected, but after i connected everything...) the update finished and i was a happy man!
so if your ps3 have been opened in the past , there is your problem.
hope i healped and good luck!
Jan 08, 2010 | Video Game Consoles & Games
PS3 Update successful,install failed,systemrebooted,error8002F14E
On the playstation 3 site error code tool says this code is an issue updating the PS3 sytem software. Try to start with the hard drive uninstalled then try again installed. If that dont help i would format the hard drive in a laptop and see if it helps. worst casr scenario you could dissasemble the PS3 and unplug tha battery on the main board and see if that helps. Good Luck
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
When i put a bluray dvd on my ps3 it said i need a encryption key
Create a folder on a CD or USB Thumb drive and name it PS3. within the PS3 folder, create a folder named UPDATE . Download the update and save it in the UPDATE folder. You can get the latest update via the following site: http://dus01.ps3.update.playstation.net/update/ps3/image/us/20090624_d69362743142953be7cb44a5fd5cc888/PS3UPDAT.PUP
Be sure to save the update in the UPDATE folder (this IS case sensitive by the way) or the PS3 will not recognize the update data.
Insert your disc or usb thumb drive and go to settings, then system update at the top, then press x. Select 'update via storage media' and start the update. once completed, your system will reboot and you will be good to go.
Jul 12, 2009 | Sony Playstation 3 (PS3) Console
My ps3 started to install a game and said an error had occoured
download the update to a flash drive on your pc then put it in your ps3 and install that way,it may take 2 or 3 trys.
Apr 16, 2009 | Sony Playstation 3 (PS3) Console
PS3 System Update won't work completly.
yes that ocurs when the update is not downloaded completely and as you have pointed out because of server problems..i had the same problem because of the same problem and had to download the update froma stable connection..i suggest that you use a formatted USB and download a fresh update perhaps from a different connection..hope it helps!
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
PS3 update problems
Hello!!
Ok, no matter how you try to install the firmware it will always write it to the hard drive first before install. Now if it gives you the 800 error while downloading it's your hard drive and it may need to be re-formatted or replaced. If you get an error during installation, then therewas a misplaced piece of code during the download and it needs to be downloaded again.
BTW, the power button default reset is ONLY for the Video output settings.
Hope this helps. Good luck and happy gaming!!
Oct 22, 2008 | Sony Playstation 3 (PS3) Console
Ps3
Download the system update from another place. Once the file on the PS3 is corrupted or incomplete it will only try that file.
You can install the system update using your PC by downloading the update to a USB stick or Memory Stick.
Get the system update here.
http://www.us.playstation.com/PS3/Network/Updates/pc_update.html
Dec 12, 2007 | Sony Playstation 3 (PS3) Console
Open Questions:
Sony PlayStation 3 40GB System Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
