Question about Whirlpool Washing Machines
Hello Expert... I have a Whirlpool Washing Machine (model LA6300 x two. has always worked fine.. but recently seemed to need to be kicked torwards the end of the wash cycle.. As of yesterday, I can't get it to complete the wash cycle.. in other words it stops shaking, then sits with full water... and does not progress through rinse and spin cycles... Is there something I can reset or check to know if this is a FATAL problem? pmougis@verizon.net 914 591-5771
  • 1 more comment
  • pmougis Apr 23, 2010
    sounds like the lid switch is the trouble...what do I do next???????
    I am going to play with the lid switch a little..
    Just double checked...
    I turned the knob to just past the DOT towards the middle of the cycle and pulled the knob out..
    the washer fed some water... then agitated for a few minutes with the pointer now 1/3 through that last section. the system has stopped... is not draining, or spinning...
    I have the lid shut.. HELP...
    Jahn... one last question... do you have suggestion on a technician or repairman in my area.. this effort is beyond my capability.
  • 10,515 Answers
Tell me Your Location and i would be able to Tell you the Nearest Repairman.
Let me know, so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 24, 2010
    President:
  • 1,554 Answers
The problem is a faulty lid switch if the washer fills and agitates but doesn't advance through the rinse and spin cycles and doesn't drain. If it fills, doesn't agitate or spin, but drains then the motor coupler is broken.
Verify the above functions and let us know which can be executed and which is not.
Posted on Apr 23, 2010
  • 2 more comments
  • Jahn27
    Jahn27 Apr 23, 2010
    Access to the lid switch connector for testing requires the removal of the
    console. Disconnect power to the washer prior to
    servicing to avoid the risk of electric shock.
    Remove the screws attaching the console then
    slightly pull the console forward to clear the console tabs from the
    slots in the top of the washer. Once cleared, flip teh console to the
    rear of the washer and disconnect the lid switch wiring harness from
    the cabinet.
    Using a volt-ohmmeter (VOM), check the continuity between the terminals of the lid switch while activating it. Set the VOM to the R X 1 scale for accurate reading. There should be a continuity when the switch is activated; otherwise it is faulty and needs to be replaced.
  • Jahn27
    Jahn27 Apr 23, 2010
    It is indeed a bad lid switch; otherwise the timer has a dead spot. Check first the lid switch as stated in the previous post.
  • Jahn27
    Jahn27 Apr 23, 2010
    Once the console is removed and the lid switch connector is accessed, you can bypass the lid switch and run a cycle. Replace the lid switch if the washer advances to the rinse and spin cycle after it is bypassed; otherwise consider replacing the timer.
  • Jahn27
    Jahn27 Apr 24, 2010
    Sorry for the delayed response due to time zone constraints. You should have indicated your location so I can help you look for a repair center near your area. Please reconsider my solution if you find it helpful in determining and solving the problem.
My whirlpool large wasjer seemed the belt was squeeking .... then it stopped spinning.. Is it worth is to get a new belt repaired or buy a newer one.
Of course it worth to change the belt, is more cheap then a new washing maschine.
After 7 years of usage my Samsung washing machine was doing same problem. I change the belt with a new one about 3 years ago, and it's working fine.
All the best !
Nov 06, 2017 | Whirlpool Washing Machines
I HAVE A WHIRLPOOL TOP LOADER MODEL 3LSR6253E01 MY WASHING COMES OUT COVERED IN LINT. I CANT FIND A FILTER ON THE MACHINE IS THERE ONE? PLEASE HELP THANKS KATE
All washing machine have lint filters to protect the pump, but they generally have quite large holes and although called 'lint' filters, they are to stop baby socks and coins getting into the pump. They are always at the bottom of the machine behind the front kick panel on a front loader or under the agitator on a top loader.
If your washing comes out covered in lint, you need to find the item that is shedding it. May also be paper tissues left in pockets. We only have one item that sheds lint and that is a bathmat. We wash it separately.
Take a look at this video.
Washer Filter Plug Kit part 285868 How To Replace
May 26, 2016 | Whirlpool Washing Machines
Awe 2117 whirlpool over flow of soap
Remove the top and and check the hose from the dispenser to the tub for clogs and see if the actuator motor is working is what I would do using this handy dandy SERVICE MANUAL( For American models)
Sorry that is all I have. If you are across the pond you may be able to a manual from Espares.
Jun 17, 2012 | Whirlpool Washing Machines
How old is the Whirlpool washing maching model # LSQ9549PWO...ser CR3028092?
July 19, 2004. go here and you can tell how old any appliance is by putting in the model,serial numbers and brand name.http://www.appliance411.com/service/date-code.php
Jan 24, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
The washing machine seems fine but will not start the spin cycle
Hello there, I got a whirlpool sport washer machine that is showing off code f-28 and it gets the door locked! I have unplugged it and have taken the toe kick plate to reach for the release lock. I select a cycle but it seems to send signals to the motor, inlet valves but it just stops and nothing happens,. so if you could help me I would really appreciate it! thanks joe
Sep 04, 2010 | Whirlpool Washing Machines
We have a Whirlpool awm8143 model front loader. works fine
this could signify that you have the outlet hose to far down the outlet pipe of the machine, or if you have it plumbed in to the plumbing under the sink you could have dirty sink water flowing back into the machine
Mar 02, 2010 | Whirlpool AWM8143 Front Load Washer
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have ? for model # ET1MHKXMQ00
Sounds like you need a new thermostat to me. They are kinda expensive, not too hard to replace though.
Jan 24, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Washing Machines Logo
91 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
