Question about Epson Office Equipment & Supplies
I have an epson Stylus photoRx420 printer. All the buttons are flashing red and will not switch on to print
  • dollyannie6 Apr 23, 2010
    The red lights are blinking continuously.
    Please tell me honestly, would it be better to scrap this printer and purchase a new one?
  • Epson Master
  • 13,433 Answers
Hello and welcome to FixYa.
If all your lights are blinking, then Unfortunately this indicates a Fatal error. If you have a Steady Error light and ink light. Then the printers waste ink tank is full, it would need to be replaced and then the printer reset.
if the all lights are blinking, its a fatal error:
This can indicate two types of problems, if the blinking happens with 2 second intervals or slower, then its a mechanical problem, if the blinking is fast, under a second intervals, then its a system error.
In all of the 3 cases I've just talked about, the printer is in need of repairs.
The waste ink tank issue involves replaing the pads / tank, and then performing a special reset done with a adjustment software, that is generally not available outside repair facilities.
Now in the Fatal error case, the issue is beyond home repair. Please take the machine to a repairer.
if you are eager and willing to spend hours in front of the printer taking it apart and trying to sort out the issue. you can obtain a service manual from epson-stylus-photo-rx420-rx425.html">http://printer1.blogspot.com/2008/06/printer-epson-stylus-photo-rx420-rx425.html
Posted on Apr 23, 2010
  • Ekse Apr 23, 2010
    Yes, That was clear from your first message. Did you have another question?
  • Ekse Apr 23, 2010
    How much does a new printer cost over there? Most likely yes, it will be cheaper, and less of a hassle to just go and buy a new cheap printer off the shelf. Sell this one on ebay or give it to someone who is interested in repairing it.
    A new inkjet is going around 20 - 40 euros where I live. a repairer will charge much more than that to repair the printer, the parts in case if its a waste ink tank issue, will cost you around the price of a new cheap printer.
    Most likely the repair will cost more than the cheapest printer that you can find.
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My Epson Stylus Photo RX425 printer will print ok then it flashes the red error light that there is a paper jam but there isn't one. I go through the procedure of pressing colour button and opening and...
Its simple Just move printer head to the right whereever it is .. Forcefully move to the right most of ur printer ..it will not damage ur printer but will solve ur problem...
Aug 17, 2010 | Epson Stylus RX425 Multifunction...
Printer does not go
After few head cleaning, ink counter running low, so ink ligh (red) flashing. Then ink counter runing out, so the light stayed on. After replacing both of ink, red light stayed on, because the compatible ink (chip) not recognized by printer. Check epson status monitor. Use original ink or refill and reset ink level counter.
May 26, 2010 | Epson Stylus C60 InkJet Printer
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
Sep 24, 2009 | Epson Stylus Photo R220 InkJet Printer
EPSON PRINTER R22O
Hi-
yes actually there is. the parts its talking about is the inkpad, you can send this over to an epson certifies servicer in your are to have inkpad change and they will reset the counters for it. go this link and look for a servicer near your place
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes
or you can contact epson at 562-276-1300
pls rate as fixya if helpful. thanks!!
Jun 21, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson won't print and all lights flash
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Mar 15, 2008 | Epson Stylus 880 InkJet Color Printer
Repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Oct 02, 2007 | Epson Stylus C86 InkJet Printer
Printer has red lights permanently on when powered up
if they were initially flashing fast there is a fatal error and a repair is needed, but always try a re install first. Go to printers and faxes folder and go to your Epson C88 printer icon, right click on it and select cancel all documents or prints, then select uninstall, to remove the printer. Uninstall driver from add/remove programmes, turn off and remove printer from usb port and restart pc. Install the drivers and software again from the cdrom and when prompted to connect printer, switch it on but connect to a different usb port if possible and allow windows to detect and install. If the lights are still steady red or flashing fast, then the printer is faulty.
May 26, 2007 | Epson Stylus C88 InkJet Photo Printer
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
