Question about Asko W6021 Front Load Washer
Asko w6021 washer not working
Washer worked fine up until this week for 6 years. First a load of clothes came out wet, then the washer would not run any of the programs. When the start button is pressed ther is just a clicking sound but nothing else happens. I replaced the circuit board thinking it may have malfunctioned but the washer still does the same thing.
  • 1 more comment
  • MarkNadine Apr 08, 2008
    Asko w6021, That is exactly what has happened to my machine. Try to start it and you hear a click and nothing else. Also my door will not open unless you use the emergency opening.
  • poddoc Apr 08, 2008
    Mark, more than likely your problem is worn brushes on the motor. They are very easy to replace and can be found on the web site repairclinic.com. Hope this helps
  • rkt52 Jul 12, 2008
    Same problem but I opened the access panel to circuit board and found a lot of residue on an area of the circuit board, on the back of board and the plastic beneath. Also some residue on inside of panel cover. The dor button works, the power light operates nut washer dose not start when you push the start button. Should I look at brushes also since I am in the unit and replace? And do you feel as I do that the board is toast? Also where and how much to get new circuit board?
    Sergeant:
  • 351 Answers
Replace the carbon brushs in the motor,they will be worn out part no 8801195,round motor.or 8801097 square motor.
Posted on Mar 23, 2008
  • Ian Greenland Apr 09, 2008
    worn carbon brushes on this model gives strange faults
Still waiting on parts we live in Sydney and the parts come from Melbourne. Hoping they arrive today as the washing is building up.
Posted on Apr 10, 2008
  • MarkNadine Apr 14, 2008
    Parts Arrived and it only took 10 mins to fix. Thanks you saved me a fortune!!!!!
How can you tell which brushes to order w/o looking inside the machine? I have my serial number here:
Serial Number 025010364848
Art number 107602100
Posted on Apr 15, 2008
  • ddlugo Sep 17, 2011
    If it's a W6021, the brushes - in the USA - are part #8801195. You need to get two of them. AskoUSA.com sells them for US$33.82 for 2 (+ shipping & handling, which can be exorbitant). They are usually back-ordered items so be prepared to wait. I'm waiting on mine plus a circuit board to replace the one that got fried when the brushes went bad. The board at Asko is US$163.81 + S/H. Cheaper than a new machine, I guess.
I have an Asko 20005 front load washer. When the humidity is high, it buzzes but will not start. When I run a dehumidifier for a few hours it works fine.
The humidity will kill the control unit if you keep trying to start when buzzing. Make sure the humidity is as low as possible. These controlunits are discontinued, and impossible to get as sparepart!
However, this is the best machine ever made!!
Jun 28, 2014 | Asko W6021 Front Load Washer
Washer not spinning properly
Hi, there may be excess water in the water reservoir. Empty the washer Turn it off at the mains, and unplug it, then put some old towels on the floor, tip the washer forward until the excess water comes out. Reconnect and try again.
Jul 13, 2010 | Asko W6021 Front Load Washer
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
My washer seems to be functioning normal, but my clothes are coming out wet enough to ring water out of them. I have to run an extra spin cycle and they still come out wetter than other machines I've...
The drive belt may be slipping.
There is an adjustment on the motor (four bolts which secure the motor) If you increase the tension on the belt and pulley, you will get a better result.
Ask me if you need more instructions on this.
Ash
Oct 22, 2009 | Asko W6021 Front Load Washer
Asko w6021 washer leaves clothes damp and often stops mid cycle
I AM NOT MUCH OF A MECHANIC, BUT I DO KNOW THAT IF WATER DOESN'T SPIN OUT OF THE WASHER, IT COULD BE THAT YOUR BELT IS BROKEN OR YOU NEED TO REPLACE THE MOTOR COUPLING.
May 13, 2009 | Asko W6021 Front Load Washer
Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
Mar 09, 2009 | Asko W6021 Front Load Washer
ASKO w6011 FRONT LOADER
Try to Open the safety compartment using a screwdriver under the wash machine in the front.
Then open the big white knodb this will cause the wate to drain out which is fine.
Then clean this out. Usually you will find coins and stuff here from years of operations from pockets. clear these out and your problem maybe fixed. worked for us
Jun 09, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
482 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
