Question about HP DeskJet 5650 InkJet Printer
Printer won't print...The ink light constantly flashes but cartridges are not low on ink. The print job shows up in the printer que but nothing else happens. Have restarted printer and computer and re-installed printer driver to no avail.
eagle338
  • 4889 Answers
SOURCE: will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Posted on Oct 27, 2007
jaylex
  • 417 Answers
SOURCE: orange flashing light on printer
No the ink is not to low you could try removing the ink cartridges and using a soft cloth wipe clean the little gold contacts on the cartridge and also the printer. Is the ink cartridge a original one if not even though the HP software states that there is 20% in there the likely thing is that the cartridge is empty replace and this should be OK.
I hope the first suggestion works for you as will not cost any money.
Thanks J
Posted on Jan 12, 2008
cene765
  • 787 Answers
SOURCE: Red light (low ink) was flashing. I got a
Red light is not for low ink.This mean one or both cartridges are failed.Who cartridge replaced?Black or color?Replace the other one and try again.
Posted on Nov 05, 2009
  • 313 Answers
SOURCE: Ink Cartridge light flashes constantly
replace with a genuine cartridges
Posted on Apr 06, 2010
Rider On Way
  • 1679 Answers
SOURCE: I have a print job that I cannot cancel. This job
Try this Utility program
http://www.fixya.com/support/r5095488-unable_print_hp_printer
Posted on Jun 23, 2010
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My lexmark Z2320 printer will not print. It places jobs in queue but still will not print. The green power light constantly flashes quickly once turned on. I have tried unplugging the printer from the main...
The flashing light on the printer indicates there is a problem. Make sure there is no paper jam or cartridges are properly installed. Disconnect the printer from your computer. Remove the sheets of paper from the printer. Open the printer cover and remove the cartridges. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges (make sure the cartridges still have ink in them). Close the printer cover and check the power light. If not blinking, proceed with loading of paper. Reconnect the printer to your computer.
Make sure the print queue has no pending print jobs before sending another print job.
Jun 18, 2011 | Lexmark Z2320 InkJet Printer
How to find ink levels in hp932c printer
Print Cartridge Status The Print Cartridge Status Light flashes when one or both of your print cartridges are low on ink, improperly installed, or malfunctioning. It will also flash if you are trying to use the wrong print cartridge type. If the problem is low ink, the light will stop flashing when you open the top cover. For any other print cartridge-related problem, the Print Cartridge Status Light will continue to flash. To check the status of your print cartridges, open the printer's top cover. The yellow arrow on the print cartridge cradle aligns with one of five Print Cartridge Status icons.
Jan 08, 2011 | HP DeskJet 932c InkJet Printer
When the start button is pushed the green light come on and the ink cartridge traverses the machine from right to left and then back to the starting position. the green light goes out and the red light...
Hi there try to power off printer then power back on, this is usually a print job that is qued up but not printing, also if you have any print jobs in your windows printer que, delete them with the printer off. this will clear the printer. otherwise check for a paper jamb.
Also try
Hello there Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 12, 2010 | HP DeskJet 845c Printer
Teardrop light is flashing yellow. Green clock at left is lighted. Control panel says everything is ready but it won't print. There is no paoper jam.
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
Jan 07, 2010 | HP Hewlett Packard Deskjet 5650 InkJet...
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=83027&lc=en&cc=us&dlc=en&lang=en&cc=us. HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
Mar 26, 2009 | HP DeskJet 6122 InkJet Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Orange flashing light on printer
Thanks J
Jan 12, 2008 | HP DeskJet 930c InkJet Printer
Blinking Light
uaually the LED blinnks when there is no ink or when it runs low on ink. But since the LED is kept there to indicate any error happens to the printer.... 1. So I suggest that you should take out the printer cartridges and check all of them....shake well before you put it back. Now open Control panel - printers and fexes - right click HP 5550 - Properties There should an option to see the ink levels. If you can see the ink levels....it means that printer can detect the cartridges. Now the printer LED should be turned off. If the above doesn't work, try this; Check the printer que .. if there are print jobs pending, the LED will blink. Delete the print jobs, and restart the machine. This should solve your problem.
Oct 02, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5650 InkJet Printer Logo
Seeker5211
Seeker5211
