Question about Denon DRA-397
I was told that a Denon DRA-397 receiver would accomodate my new Bose 901s, but I haven't had any success in connecting my Bose amplifier to the receiver. How does the amplifier connect to the receiver. I also have a Denon Ipod dock connected to the receiver.
  • 1 more comment
  • mfarless Apr 23, 2010
    The problem I have is that there is only one CDR/TAPE in and one CDR/TAPE out connection in the back of the receiver, and the Ipod dock uses the CDR/TAPE in conncection. The Ipod works normally this way. However, that leaves me with only a CDR/TAPE out connection for the Bose amplifier. Does this mean that I can either listen to my ipod without the Bose amplifier or listen to something else with the amplifier?
  • mfarless Apr 24, 2010
    That worked!!! Thanks a million!
  • Dennis Hofferber Nov 30, 2011
    how do you hook up the bose 901
  • Denon Master
  • 6,993 Answers
since your receiver has only one input and output, I believe your Bose amplifier should have more then one input. So I would suggest you do it this way:
  1. Check the back of your Bose amplifier, there should be an output there. Connect the output from your Bose amplifier, to the input of your receiver.
  2. Then connect your I-pod duck and other devices into the IN of your Bose Amplifier.
By so doing, you Bose amplifier, will be the main source for listening to your sounds.
I hope you understand my message.
Good luck.
Posted on Apr 23, 2010
  • 17,970 Answers
Are you sure that all connectiosn are OK? I suggest check the procedure in the next installation GUIDE.
Tell us news.
How do I hook up my bose 901s to this unit?
Well the basic connection of the speakers would be the same as another stereo speaker pair. Wire the left and right speakers to the L/R Front Surround speakers on the Denon.
With the 901's I am assuming that there is an external equalizer supplied by Bose. Typically this EQ is installed in a tape loop on the receiver/amp so that it is ahead of the power amplifier that drives the speakers. This EQ needs to be there to attempt to get reasonable frequency response from a speaker that has only 4" drivers. I'm not sure I see any reasonable way to make the EQ work with the Denon AV receiver. You'd likely be better off using the Bose speakers in a dedicated 2-channel stereo and getting a set of speakers for the AV usage.
Apr 16, 2016 | Denon Avr 3805 7.1 Channel Audio Video...
Denon DRA-397 zone 2
zone 2 is just for an extra set of speakers in another location, your sub is not attatched to that zone
May 21, 2013 | Denon DRA-397
Zone 2
I would consult your owner's manual but I don't think you can adjust the bass/treble levels on the zone 2 outputs.
I have a Denon DRA 397 receiver and when I power it up the standby light goes on but nothing else powers up?
If you are not pressing the power button on the remote that may be the problem
Apr 11, 2012 | Denon DRA-397
Dra-397 shuts down 1 second after turning on
There's a couple of possibilities; power supply shutting down because of a fault within it; the PS shutting down because of excessive current drawn and that can be caused by a failure in the final amplifiers which are probably modular in design.
Apr 24, 2011 | Denon DRA-397
Denon dra 397 shuts done if I turn on both zone a & b. Have a 100 watt volume control on each pair of speakers. Works fine with only zone a or zone b on, but not both.
Let's understand this - you have an external volume control wired in series with each front speaker set?
Can you elaborate on their electrical characteristics?
http://www.retrevo.com/support/Denon-DRA-397-Receivers-manual/id/696dj087/t/2/
Page 24.
A + B 8 - 16 ohms
Jan 22, 2011 | Denon DRA-397
Denon DRA 397 Won't Turn On
me too did you ever get it fixed
Dec 16, 2008 | Denon DRA-397
Denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Oct 13, 2008 | Denon DRA-397
Stereo receiver is in a Panel Lock On mode and will not stay on
Hi, Press the B and the Mode buttons and then hit the power button.  This should unlock the panel....it worked for me.
Apr 12, 2008 | Denon DRA-397
Denon DRA-397 Logo
238 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
