Question about kawasaki Full Suspension Mountain Bike Men
Have put a new piston kit in my 1993 kx125 dont have a kickstart and it wont bump start 4 some reason,theres fuel going through and there is a spark but a weak one will just a new plug get it going?
    Problem Solver:
  • 8 Answers
How long was your bike sitting for when you did the new piston? change the old fuel out the tank if the bike has been stood for along period of time the fuel may have gone off. have you installed the piston the correct way round?
Posted on Jul 07, 2010
I have a baja 90cc quad it dose not have kickstart i put in the key and it wont start i got a new sparkplug and a new battery still wont start
Do you have fire at the spark plug. If so check compression, then if not check fuel system(( carb)
Jul 29, 2017 | ATVs
Hi i have rm85 and the kickstart wont budge dont know much about bikes all and it wont bump start either any clues how i could fix this or what the problem is
First thing is to find out if the crankshaft will turn. Remove the spark plug and the roundish cover on the left side of the engine which should expose the ignition assembly. Put a socket on the end of the crankshaft and see if it turns freely. If it doesn't, you have a seized piston or other internal problem.
Aug 08, 2014 | Motorcycles
My kx 60 wont kickstart but it will bump start
Sounds like low compression. Do a compression test,and it should have at least 90psi,..if not,its time to rebuild the top end..(piston,rings,bore)...pretty common for two strokes.
Aug 29, 2012 | kawasaki KX 65 Motorcycles
Aprilia mx 125 bogs down while riding then cuts out
Dont waste your time looking for something else. Go ahead and pull the spark plug and do a compression test. It should have at least 100psi. If not,its time for a top end rebuild. It gets worse when it gets hotter because the ring gap expands,and loses what little compression it has. Best to check the compression and rebuild the top end now,before the piston or rings break,and cause lower end engine catastrophe...
Aug 29, 2012 | 2005 Aprilia MX 125
1993 honda acord wont start there is fuel going to the intake but wont start and if i tried to put fuel directly in the intake tried to start to wath can i do ???
Did you check the spark? Pull a plug and reconnect it to the wire and lay it on a piece of metal away from the piston hole, (flame thrower) And click it over to see if it sparks. If no spark, you have a bad coil or coil pack. You should be able to find one in a junk yard, don't go out and buy a new one, it could be something else. Like low oil, fuel pump, ignitor, etc. If it sparks, squirt a little fuel into the spark plug hole and fire it up and see if it fires that way. Have to narrow this down to something. Check it out, hope this helps.
Mar 02, 2011 | 1993 Honda Accord
1977 yz80 wont start. Cleaned carburetor, checked magneto, but cant get to start having problems getting spark, replaced plug.
If you have a spark, but weak. It is possible that your flywheel is demagnetised. Then you'll need a spare.
If sparks are good, then the spark plug should be moisted with fuel after a few ( 10 ) choke kickstarts. If so you'll have a weak compression. Then you have to at least clean out the piston ring grooves ( dismount cilinderhead and cilinder ), or even change the piston rings or overbore the cilinder and place a new oversize piston kit.
If spark plug stays dry when kickstarting, the carburettor is faulty. Clean it out, check also the choke system. Check the air intake between carb and cilinder for air leaks.
Oct 04, 2009 | Yamaha YZ 125 Motorcycles
I need a diagram manuel that shows pictures on how to rebuild a 1993 suzuki dirt bike
take off the 4 bolts on the head after you unplug the spark plug. then take out the c clips that are on the side of the piston where it connects to the crank oh ya if the cylinder wall is scarred then you will need to repair or replace it, but if not then keep following after you take out the clips the piston should come off im assuming you bought a rebuild kit now take the new piston and place the ring(s) on it then put the piston on the rod then slide the shaft inside the piston then put the new c clips on each side then place the cylinder on top of the piston (you will have to clamp the rings together with a special tool but if you dont have it your fingers will work fine then after you get the cylinder on you can put the bolts back in place then the spark plug wire and remember to break in the new top end by driving in first gear for a few hours.
Jul 21, 2009 | Suzuki RM 125 Motorcycles
I got a 1995 cr250 dirtbike and i have a problem starting it it wont start but keeps back firing the bike has a bran new rebuild it allways had a problem starting it. but now it wont start i took the carb...
im thinking if it has spark and getting gas and has compression, the bike will run. sometimes a "WEAK" coil will give a good spark, but under compresion its not enough to ignite the fuel. if thats not the case, take the air filter off and spray starting fluid into the carb and with NO CHOKE, give it full throttle and kick it over. if that dont do it try compression starting it, tow it for some distance if you have to. if that dont do it, then there must be something wrong with the carb. jets, fuel air adjustment. thats all i have. good luck.
May 06, 2009 | 2003 Honda XR 125 L
Kx 125 1992 wont start
sounds like the rings are fried and needs a new piston and rings.. for an 80 there about 110 bucks for the whole kit
Feb 17, 2009 | 2003 kawasaki KX 125
Yz 250 wont kickstart
Hi!
You obviously look after your machine and very sensible when laying up, however as you are probably aware 2 strokes rely heavily on compression, A. to produce excellent combustion and B. to draw fuel into the chamber. So when you try kick starting you can't get enough revolutions to draw the correct amount of fuel into the cylinder, where as you push start you constantly turn over the engine increasing compression slightly and bingo it fires.
Can you remember how when kick starting it before this problem the feel on resistance when kicking over? has it now become a lot easier? if so you possibly have worn or broken compression piston rings.
A compression test will reveal this, I hope this sorts your query?
Press the Blue button please for my FREE effort,
Thank You!
Paul 'W' U.K.
Feb 06, 2009 | 2000 Yamaha DT 125 R
kawasaki Full Suspension Mountain Bike Men Logo
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
