Question about Epson Stylus C86 InkJet Printer
Have put new ink in and is not printing, when printing i get a message up in German so i do not know what it says. Cannot do a test page need a disc for epson stylus DX5050
jonniewalker
  • 1031 Answers
SOURCE: how to reset my epson
If your Epson printer needs resetting you can download the latest software Version of the SSC Service Utility (V4.3) from this link.
Install it and run it, click on configuration, select your printer from both lists ('x' is replaced by a number), close the program with the red cross. The program will run in your task bar, click your right mouse button on the icon for a menu. You can use the appropriate utility for your needs, if your printer needs maintenance due to ink pad being full, select Protection Counter and Reset Protection Counter. If your printer has locked out because you ignored the warnings and continued printing, first select Protection Counter and Clear Counter Overflow, then select Extras and Soft Reset, wait 5 minutes, then select Protection Counter and Reset Protection Counter.
Posted on Sep 23, 2008
tigertail
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
SOURCE: EPSON STYLUS CX5500;-Document prints from file
send for me manual epson stylus cx5500
Posted on Apr 11, 2009
aicaxz
  • 511 Answers
SOURCE: No blue ink
It's seem the cyan head is clog, try the head cleaning use software or manually using head cleaner.
Posted on May 29, 2009
  • 26 Answers
SOURCE: epson stylus dx4000 printing blank pages . how do
replace cartriges, clean printers heads from utility menu
Posted on Oct 25, 2009
My hp 4280 all in one printer says i am out of ink both cart are new.
Good day.
Choose Tools>Print Test Page and check if you still get the same message out of ink. Also check the ink level report on the page which is very important.
If it says out of ink or ink level report shows no ink, check the new ink cartridge and take off the plastic cap off the nozzle.
Reseat the ink cartridges, restart your printer. (Power it off then back off) Check if it's the same issue. If it is,it would also be best to Align the Print head. Setup Menu>Tools>Align Printhead.
Jun 28, 2011 | HP Photosmart C4580 All-in-One InkJet...
My printer says it's out of yellow ink, but has been refilled, twice with new cartridges. How can I fix this?
May I know the product number of your printer?
however before we proceed with the issue, I would like to tell you that HP printers do not support the refilled cartridges, or the message you are getting could be a false message, print a test page to confirm if the printer is printing yellow ink or not. you could also check the ink level on the test page
Apr 14, 2010 | HP Photosmart C6180 All-In-One InkJet...
Photosmart 5580. How do I turn off the annoying
Because it is a photo printer it knows that the print heads must be aligned for optimum reproduction. You get a new print head with each cart.
For the amount of ink a test page uses I can't see the reason for complaint. If you begrudge the miniscule amount of ink and are not bothered about the best possible printing then just ignore it.
Jul 30, 2009 | HP Photosmart C5580 All-In-One InkJet...
Put in new ink and it is telling me out of ink and will not let me print anythings.. How do you reset ink
Simple oly when you know how ;-)
I think you have a slight blockage, to solve:- (dont know which printer or PCyou have so ill do my best)
Click on Start
All programms
Pick your printer from the list
Open the software
You will have 2,3 or 4 options depending on your printer spec.
You need to 1st remove the cartridge
Print 1 page with no INK a message will pop up saying con not print need ink for example.
You then NEED to calibrate your cartridge, you need to find:-
1 Align Cartridge/Nozzle - Unblocks, and Sets up. (Syncronize)
2 Calibrate Black - unblock black
2 Calibrate Colour - unblock colours
3 Print test Page - See how it looks
5 Align again - Unblocks everything giving good ink flow and gets the print right close to 100%
6 print test page!
It shoud now work ;-)
Good Luck xxx
Jul 15, 2009 | Canon Pixma MP480 All-In-One InkJet...
Check ink u163 error message
Firstly I suspect you are not using genuine cartridge or you have refilled the cartridge.
To fix this you need to disable the ink checking procedure.
Do you know that low ink or ink has run out message appears once cartridge empty. If you want to use refill ink in that cartridge then you need to deactivate ink level to get your printer run as usual. Check the following tips to fix low ink error message in case of refill ink usage. Below some methods to deactivate ink level detection function for some models due to its similarity.
METHOD I:
Press RESUME/CANCEL button once
Related models:
BJC series: bjc3000,8200,etcS series: s400,600,800,6300,9000etc
i Series: i255,320,350,355,450,470d,550,560,850,950,6100,6500,9100,etc
Pixma series: ip1000,1200,1300,1500,1600,1700,2000,2200,3000,4000,etc
METHOD II:
Hold down RESUME/CANCEL button for 5 seconds or more
Related models:
Latest models of Pixma series: ip1880,1980,3300,3500,4200,4500,5200,6700d,pro9000,9500,ix4000,5000,etc
METHOD III:
Press START button once, select COLOR button for colour cartridge; BLACK button for black cartridge
Applicable models:
Pixma MP150,160,170,180,450,460,475,etc
METHOD IV:
Hold down STOP/RESET button for 5 seconds or more
Applicable models:
Latest models of Pixma MP/MX series: MP145,228,245,520,800,850,970,MX308,318,7600,et
Jun 21, 2009 | Canon MX300 Office All-In-One Printer
WHILE TRYING TO FIGURE OUT WHY MY PRINT QUALITY IS SO POOR. AFTER CLEANING THE HEADS A FEW TIMES I WENT TO PRING A "QUALITY TEST PAGE". The MFC said i was out of paper. i refilled the paper (with the...
the messages you get for cartridges other than the original are not trustful. You will get the right reading for original(from Brother) cartridges. Some ink is poor for printing photo quality.
not any refillable ink is right for printing photos, sometimes too dark, sometimes you don't get the right mix of colors.
Mar 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
Cannot print with new ink cartridge
Sounds like a non genuine, aftermarket ink that is dodgy.
if not ensure it is indicating the same colour that you replaced
Dec 12, 2008 | HP Photosmart C6280 Printer
Printer message is 'remove and check cartridge'. have done that and put in new cartridges but message stays. can print a test page but it will not print anything else
I assume something has happened during a print job and you are seeing this message on the 6110's control panel display. Either there's a "clog" in the flow of ink or an issue with the electrical contacts between the cartridge and the print carriage. Unfortunately, HP.com doesn't list this error message on the web page for 6110 errors.
You can go to the following web page and follow the instructions to clean the electrical contacts I mentioned. The problem you are seeing can also be caused by an incorrectly installed ink cartridge or one where the protective tape strip was not removed before installation.
The latter is likely if you see this error message right after you've put in a new ink cartridge. It's easy to put the cartridge in incorrectly or not to correctly latch it in place. It's also really common to forget to take the tape off before installing the cartridge.
Here's the relevant link:
Cleaning the Print Cartridge
Good luck and post back your results.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark all in one 4270 won't print in black
I know your problem. I just put in new cartridges and it will print the test page, but nothing else. Did you get an answer
Sep 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Epson Stylus C86 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
