Question about Dell 1600n All-In-One Laser Printer
Paper jam 2 paper inside"
Display says "paper jam 2 paper inside", can't see any paper, checked back and front, took the inkjet out - nothing, does not print, scan or copy
SOURCE: Lexmark X3350 Printer
i think i found a solution for this.
its happen when you insert the papers to deep in the paper
jam jusy try to pull out the papers.
if its print its great , if not it should say load paper so in that
moment push the papers a little deeper.
Posted on Dec 22, 2007
otacon
  • 1944 Answers
SOURCE: My paper keeps jamming
Clearing paper jams Paper jams can occur for a variety of reasons but are usually paper related. Follow the steps below to clear the paper jam:
  1. Turn off the all-in-one and unplug the power cord. With the power off, the paper feed rollers will turn.
  2. Open the rear access door of the all-in-one by pressing in on the left side of the access door and then pulling it toward you. NOTE: All paper jams must be removed by pulling the paper out the back of the all-in-one using the rear access door. Pulling the paper out the front of the all-in-one rotates the paper feed rollers in the wrong direction and can lead to additional problems. Figure 1: Rear access door c00101861.jpg Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
    • If under warranty, contact HP to obtain a replacement part.
    • Click How to buy on this page to order replacement parts.
  3. From the rear access door opening, gently pull the jammed paper free.
  4. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray. Do not continue to push the paper in after some resistance is felt. If the paper is pushed in too far, more than one page will feed into the all-in-one at a time.
  5. Reattach the rear access door by inserting the two pins on the right of the door into the holes for them (as shown in Figure 3 below) and then pressing in gently but firmly on the left side. Figure 2: Inserting the rear access door guide pins into the holes c00099183.bmp
  6. Reconnect the power cord to the unit and turn the unit on.
Posted on Jan 08, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Always paper jam.
Check to see if something isn't blocking the paper path.
You could try cleaning the feed rollers as well.
Posted on Jun 12, 2008
SOURCE: Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Posted on Jun 19, 2008
SOURCE: printer keeps reading paper jam
We had exactly the same problem (and this printer had never been used before) - we fed a piece of thick-quality paper, applied a little pressure from the top edge as it descended, and 'voila' the printer has finally fed one sheet right through.
What it is NOT yet doing is aligning correctly with the top margin of the document - it is more or less cropping off the top portion, but I'm trying to finish taxes and this will darn well do for now.
These printers are cheap plastic junk, manufactured to make the trip to landfill as soon as possible. Damn Canon and all the other corporations making these trashy pieces of electronics. (I still have a LaserJet 5MP, and I'm sure HP hates me for it - circa 1995 manufacture). If I can figure out how to get printer drivers for OS 10.5 (mac) it will leave to see more service still. Grrrr.
Posted on Apr 10, 2009
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Paper is jammed
Only 2 things can be done. Switch it on or off repeatedly, the paper will automatically come out. Second, disassemble it and take out the papers.
Audi Headlights
Aug 27, 2012 | Canon PIXMA MG2120 Photo All-in-One Inkjet...
I cannot print or copy . i see error 51
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
Is there a fix for error 6A80 for a Canon mx700 printer?
You can try a few things:
RESET the printer:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Check for paper jammed in the paper output slot, the Rear Tray, or the Front Tray.
Remove the paper following the procedure below.
(1) Slowly pull the paper out, either from the paper source or from the paper output slot, whichever is easier.
(A) When printing from the Rear Tray
(B) When printing from the Front Tray
bullet_s.gif If the paper tears and a piece remains inside the machine, open the Scanning Unit (Printer Cover) and remove it.
After removing all paper, close the Scanning Unit (Printer Cover), turn the machine off, and turn it back on.
* Be careful not to touch the components inside the machine.
bullet_s.gif If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step 1, all print jobs in queue are canceled. Reprint if necessary.
i_note.gif Note
bullet_s.gif When reloading the paper in the machine, confirm that you are using the correct paper and are loading it into the machine correctly.
bullet_s.gif A5-sized paper are suited to print documents consisting mainly of text. We do not recommend using such paper to print documents with photos or graphics, since the printout may curl and cause paper exit jams.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, you should take the printer to a service shop since the printer will have to be disassembled to remove the torn paper.
Oct 16, 2009 | Canon MX700 Office All-In-One InkJet...
Canon mx700 won't print displays error306
Open the top of the printer as if you were going to change the ink cartridge and push the cartridge to the left. Reach your hand inside and see if the paper from the jam is truly out of there. Sometimes when you pull the paper out the front or back from a paper jam there can still be something stuck inside that is gumming up the works.
Jan 06, 2009 | Canon MX700 Office All-In-One InkJet...
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper jam
hi this is some small pieces of paper which had gone inside in ur printer when u prints. this one have to contact printer engineer to clean the printer
Mar 02, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Jan 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
Dell 1600n All-In-One Laser Printer Logo
32 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
