Question about Kenmore Dishwashers
Kenmore ultra wash dishwasher model 665 15831791 did not drain and has no power
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
SOURCE: Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Posted on Feb 08, 2008
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
dcvxzcxzcxzczxc
Posted on Feb 26, 2008
SOURCE: Kenmore Ultra Wash Dishwasher: Lock On Button Issue
Have to hold the Air Dry button down til your finger hurts. Release button and the light will go off. The "4 second press" in the manual is incorrect!
Posted on Jun 24, 2008
SOURCE: My kenmore ultra wash model
my model #665 dishwasher will not pump water into the unit
Posted on Jul 15, 2008
I have a Kenmore ultra wash dishwasher model 665.17604 that will not drain. Any suggestions?
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Mar 13, 2011 | Kenmore Dishwashers
My Kenmore Ultra Wash Dishwasher Model#665.13842K600 doesn't fully drain a the end of the cycle. There is always dirty water left in the bottom of the unit.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
heatman101
Oct 02, 2010 | Dishwashers
I have a Kenmore ultra wash model 665, stock# 15951. When the tub starts to fill the water runs out the drain.
This means there is either an air gap in the drain hose or the drain hose loop is less than 32" high preventing back flow
Sep 18, 2010 | Kenmore 24 in. 15159 Built-in Dishwasher
Dishwasher will not turn on
Bruce, It would be great to know the model number of your your Kenmore Ultra wash dishwasher, please look on the right hand side of the door for a model/serial number if possible.
First steps: With no power, please check how the dishwasher gets power. If it is plugged in to an outlet under the sink, please confirm that it is plugged in fully. If that does not fix the problem and if it is plugged in, remove the dishwasher plug and plug in any lamp or small appliance and make sure it turns on.
If no power at the outlet, check the house circuit box for a tripped breaker/blown fuse. Also, check if any of the outlets have GFI (Ground Fault Interupt) circuit protection. Reset that outlet (even if it is not not the same outlet as the dishwasher is plugged in to.
Next steps: If the dishwasher is connected to a live circuit but still does not work, a component in the dishwasher has probably failed and a service call is in order. Or replacement of the dishwasher, depending on its age.
Please accept this solution soon after walking through the steps - or add a comment with an update and I will try to help more.
Mar 28, 2009 | Dishwashers
Kenmore Ultra Wash III Dishwasher will not drain properly
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Dec 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Will not drain
can you see the check valve? may have something blocking it closed.
Oct 29, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore ultra wash model 16625691
looking for a black/almond front replacement panel for my Kenmore dishwasher model #16625691. Any sugguestions as to where to find one?
Oct 17, 2007 | Hobart AM14-253 Free-standing Dishwasher
Dishwasher will not start..we've had it about 3 to 4 years
Some of these units have a thermal fuse in line with and mounted on the control card. This will need to be checked. Also check the door switches. Some models will aloow power to the control card but to nothing else.
Oct 12, 2007 | Kenmore 16872 Built-in Dishwasher
Dishwashers Logo
271 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Adam Dower
Adam Dower
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
