Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
Runs rough and will not stay running then will run for short time ok
    Master:
  • 342 Answers
Clean out the carburettor and fuel tank
Posted on Apr 27, 2010
91 xj6 will not stay running idles rough for short time and then dies out
Any codes?could be a misfire and could plug catalytic converter.
Feb 15, 2017 | 1991 Jaguar XJ6
98 Valkyrie running on 3 cyls
Coils on multi-cylinder bikes usually have one coil for 2 cylinders.
Apr 25, 2013 | Honda F6 C Valkyrie Motorcycles
At startup, car runs rough. After short time it clears up and runs ok. I put in Seafoam to remove possible moisture in gas.
Have someone start it for you in the morning while you stand behind the car. After it starts, smell the exhaust. See if it smells sweet, kind of like maple syrup. Also are you having to add antifreeze. If yes to both, you might have a head gasket starting to seep.
Jun 17, 2010 | 2002 Cadillac Deville
When car is cold it seemingly runs on 3 cylinders
seem like you got the same problem as my scion xa, check the fuel pressure regulater. bad regulater some time smell like leak gas. auto zone might cause you about $80.00.
Feb 09, 2009 | 1992 Honda Accord
Random multiple misfirings
Here is a list of possible causes. You should not drive the vehicle if the check engine light is flashing all the time, you can cause even more damage. It could pay to have a professional find the real cause.
Spark plugs that are incorrect for the application, cracked, improperly gaped or worn can cause the engine to misfire or run rough at all times.
An IC module that failed to correctly control the ignition coil(s) will cause the engine to misfire or run rough at all times.
Poor connections, broken wiring or wiring that has shorts to ground can cause the engine to misfire or run rough at all times. NOTE: Check connectors that might be pulled apart as the engine flexes or wires that short to ground as they pass near brackets or shorts to ground on the exhaust manifold.
Fuel injector(s) that are shorted, plugged or partially restricted can cause the engine to misfire or run rough at all times.
An ignition coil(s) that has low output, corrosion on the coil tower(s), is carbon tracked or arcs to ground will cause the engine to misfire or run rough at all times.
A PCM that failed to properly control the injector or ignition timing will cause the engine to misfire or run rough at all times.
Feb 02, 2009 | Saturn SL1 Cars & Trucks
Runs rough then clears up &runs great
found waste gate on turbo sticking freed up ok now
Sep 21, 2008 | 1991 Volvo 940
Ford Escape 3L 2002 Rough idle
generally, when the engine is washed, water gets trapped behind the spark unit and stays there, creating a shorting path for spark plug current. best to dis-mount the spark unit (follow plug wires back to source) and dry and clean it thoroughly.
Jun 19, 2008 | 2002 Ford Escape
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
116 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
