Question about Microsoft Xbox Console
My disc wont work i left it in my xbox 360 for a few hours after playing it and then it mysteriusly broke
How old is game does it have wornty stell if not use glaess clener or tooth paste if thay do not work look on youtube
Posted on Aug 09, 2012
  • 39 Answers
It probably broke becuase you moved the xbox while the game was playing or you put the xbox from lying down to standing up or standing up to lying down this causes the disk to shift inside of it and scratches the disk when it loads up im sorry to hear of that
Posted on Apr 24, 2010
My odern Warfare 2 is broke and i already have one burned to my harddrive and it still doesn't work. HELP
if your disc is broken then it wont matter if it is saved to your hd because you still need the disc to play. hope this helps
Sep 01, 2010 | Activision Call of Duty 4: Modern Warfare...
My disc wont play
Try your xbox in different position. sometimes it works that way. The laser might be getting weak as well. Try cleaning it, if still not working then you have to replace it.
Jun 04, 2010 | Microsoft Xbox 360 Console
Wont play any game at all
Could be a few things but seems like the most common of problems: your eye has broke and it's not reading anything on the discs anymore. Or if it's just one disc not playing, the disc could be scratched or broken.
May 24, 2010 | Microsoft Xbox 360 Console
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Xbox 360 wont play games
If your Xbox 360 will not read your games this is because of the sensors on the back of the drive taking too much heat.
You need to send it in to get it fixed or you can fix it yourself using a good guide
Feb 05, 2010 | Microsoft Xbox 360 Console
Wont play on my xbox 360 new hour of victory game says wrong region wont play
This sadly means the game and Xbox 360 console aren't the same region. (Rather the game is region locked, meaning unless you have a Xbox 360 that plays those regions, the game is non-playable because the console can't read the disc.) There really isn't any solutions for this, other than take the game back to the store and ask for your money back because the region of the game doesn't play on your Xbox 360. Always make sure when buying Xbox 360 games that it's the right region code. (Or that it's a region free coded game) There are a few games like that out, one being Borderlands for example.
If it says PAL on the cover of the game for example, the game covers most of Asia, Africa, South America, Australia, New Zealand, and most of Western Europe. (List of common PAL regions can be found here.)
There are a few other region codes for games, so you better make sure you are buying the ones for your region.
Hope this was of some help.
Jan 16, 2010 | Video Game Consoles & Games
Xbox 360 wont load any disc and have tried 7 steps of repair on your websitse and it still wont work
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this mayhappen:
Jan 15, 2010 | Microsoft Xbox 360 Console
I have a xbox 360 but it says i cant play any xbox 360 games
if it says " disc is unreadable" then u have to clean it, then restart ur console. and that happens to me all the time. just keep opening and closing ur disc tray untill it works. thats's what i do with modern warfare 2
Sep 25, 2009 | Microsoft Xbox 360 Console
KEEP SAYING UNPLAYABLE DISC My xbox 360 keeps reading unplayable discs but if i sit there long enough and keep turning it on and off, it will work. But after doing it for half an hour it gets really...
Sounds like the laser is starting to go bad in your dvd drive if it has to read it a few times before it might see the discs.
The laser is inside of the dvd drive and it looks like this:
http://www.amazon.com/Xbox360-Xbox-360-Drive-Laser-Replacement/dp/B000V78Q9O
Depending on the manufacturer of the drive will depend on the laser you will need to get.
You could also take a can of air in the meantime and blow some into the drive to make sure that there is no dust or dirt on the laser as this could cause that message as well.
May 23, 2009 | Microsoft Xbox 360 Hard Drive (20GB)
My halo 3 wont work
probably your xbox 360 broke the disc it happened to me. the only thing you can do is buy a new one.
Apr 18, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
47 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
