Question about Lexmark X5470 All-In-One InkJet Printer
1 Document Pending... can't print without deleting the Doc. but the Doc. will not delete... any answers?
  • 4,041 Answers
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
Pending documents wont print
Your buffer is overwritten. You need to right click on the pending document and select delete it would be easy to delete those processes which are not bufferrred but to delete top document you will have to switch on and off your printer. wait for a minute and restart your computer. You can start printing again.
Mar 18, 2010 | Office Equipment & Supplies
Everytime I try to cancel the pending document it doesn't do anything just stays the same, so that does not allow me to print anything else because for some reason that pending doc. won't erase... please...
first do a right clickon the printer icon
select run as administrator if there or else try cancelling the document
if still does not work
go to run and type "services.msc" and it will take you to the services page
in the services page look for a service "print spooler "
restart the print spooler
and then try deleting the documents .......................... hope this should work for you let us know wat happens and we will help you accordingly ......take care ............god bless you ...........thank you (HAMID)
Oct 29, 2009 | HP Officejet 5610 All-In-One InkJet...
I can't delete a print job in the queue . I right clicked and hit cancel. It said it is deleting it but that has been over an hour without removing it from the queue. Now I can't print anything while it is...
hi this is kamal...
go to start option there is print and faxes option pls click on that a window would appear and it will show your printer name, double click on that there would be ur pending document and delete on that and restart your system and 100% if would be deleted...
have fun..
Oct 07, 2009 | HP Officejet Pro L7680 All-In-One Printer
My Hp 1510 won't let me cancel a document in the queue
Microsoft has the help you need.
It is a common problem but the answer is here
You need to refer to method "D" about half way down the page
Once you clear the print job delete your extra printer installation
Hope that fixes you up
Aug 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP5510 Printer not working
WHAT IS THE OPERATING SYSTEM THT YOU ARE USING
IF THAT IS xp OR vista
GO TO THE PRINTER SPAGE AND RIGHT CLICK ON THE PRINTER AND SELECT RUN AS ADMINISTRATOR
SELECT CANCELL ALL DOCUMENTS AND SEE IF IT CLEARS THE PRINT QUE
STILL IF IT DOES NOT DELETE THE PENDING DOCUMENTS
GO TO SERVICES.MSC WHICH YOU CAN TYPE IN THE START SEARCH OR THE RUN BOX
LOOK FOR THE SERVICE NAMED AS "PRINT SPOOLER "AND MAKE SURE THAT THE SERVICE IS STARTED IF THE SERVICE IS ALREADY STARTED RESTART TEH SERVICE TWICE OIR THRICE
AND THE DOCUMENT WILL GET CANCELLED
BEFORE GOING AHEAD AND PRINTING TRY PRINTING A TEST PAGE FROM THE PRINTER P[ROPERTIES PAGE AND THEN TRY PRINTING OTHER DOCUENTS IT SHOULD PORINT OR ELSE GET BACK TO US AND WE WOULD BE MORE THAN HAPPY TO HELP YOU
THANKS AND REGARDS
HOPE THIS SHOULD WORK
BEST OF LUCK
Hamid
Apr 03, 2009 | HP Office Equipment & Supplies
Document pending will not print
Well this could be a number of issues. First of all try to make sure the printer is on, (yes I know very stupid request but I've seen it happen thousands of times). Then make sure the printer is connected to the PC, either via USB or LPT port or whatever the case maybe. Thirdly, you want to make sure that the printer is installed on the PC. If you goto START/PRINTERS & FAXES, and see if there are any other documents that are stuck or pending, try to delete them out or delete the printer and reinstall it. Then try to print again.
Mar 22, 2009 | Office Equipment & Supplies
My printer won't let me cancel printing documents.
This is a common problem with Windows. You don't need to delete the printer or re-install anything. If a job gets stuck at 'deleting, just reboot and when the PC comes back up the job will not be in the queue any more.
Feb 15, 2009 | HP PSC 1510 All-In-One InkJet Printer
Documents won't delete out of que Epson CX8400
Are you using Windows XP? If you are go to Start, Control Panel, Administrative Tools, Services and stop the Print Spooler Service. This should clear the pending print jobs.
Then re-start the service.
Jun 17, 2008 | Epson CX8400 All-In-One InkJet Printer
Won't print
Ok I just solved a persons problem that is very similar to yours. OK So I'll just paste what I told the other person. You might have tried printing a doc/app out earlier and it might have failed so while you trying to print out this present app/doc the printer still might be focused on that failed or it might be confused. Now to stop this follow these instructions. Go to the start bar click control panel. Then once that window pops up ( control panel ) click printers and other hardware. Then once that window pops up ( printers and other hardware ).  Click Printers and faxes and that page will have all the printers and faxes ever installed to your computer. Now click on the printer thats yours and then a smaller wider window will appear you will that window will have all the doc/app you have ever tried printing out. the status bar will show what is going on with each doc/app. Now you should first stop all the doc/apps and refresh. To do this you should highlight all the doc/app and then go into the document tab ( there are several tabs in this window such as document , printer, view and help) then click cancel and cancel all the doc/apps. last step is to go into the view tab and click refresh and it should work :-). If not contact your printer manufactor.
May 26, 2008 | Compaq A1500 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
865 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
