Question about HP DesignJet 488ca InkJet Printer
Deskjet cuts in the middle of a print
Hello, Has anyone an idea why my Deskjet suddenly cut in the middle of the image i am printing? It prints just fine and suddenly makes a cut. Not throug the whole but about 20 centimeters. after that it prints on as nothing has happend.
  • 77 Answers
SOURCE: Tops of letters are cut off when printing.
This is usually caused by clogged or burned out printhead nozzels. You can try putting the unit through a couple cleaning cycles. If that does not help, then replace the cartridge with a new HP BRAND cartridge. Do not trust refilled or compatible cartridges in this case. The heating elements in the individual nozzels can burn out causing your type of problem. Let me know one way or the other Ed
Posted on Jun 01, 2007
CompuGuy44
  • 432 Answers
SOURCE: Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
  1. Make sure that you are using the same printer driver that gave you the error in Microsoft Word Viewer.
  2. In Word, on the File menu, click Page Setup.
  3. Click OK.
    You receive a warning dialog box about the unprintable regions.
  4. Click the Fix button.
  5. Save and close the document.
You can now open and print the document in Word Viewer without receiving the error message.
Posted on Dec 19, 2008
tsaros90
  • 10 Answers
SOURCE: printer cuts off bottom of words
I think Its not a printer problem. I guess you must see the borders you have used in Ms Word (if thats you re using).
Posted on Jan 19, 2009
  • 566 Answers
SOURCE: Last line or two of print gets cut off
I have seen this suggested in a HP Support Forum. See if it solves your problem:
1. Go to your printers folder, right-click on (the network connected) printer that you are having the problem with and select "Properties"
2. When the properties window opens, click on the "Ports" tab.
3. Near the bottom of the Ports tab window is a check box for "Enable bidirectional support", uncheck it and click "OK"
Posted on Jul 29, 2009
  • 10 Answers
SOURCE: deskjet 3940 won't print using microsoft wordpad but works otherw
You will kick yourself !
It drove me crazy for 3 days and I had tried everything ! reloading the software, full system restore and pulled what little hair I have OUT !
I had exactly the same problems my printer which is an HP Photosmart 2610 all in one,would print photos and everything else EXCEPT anything from wordpad,notepad or similar ! the pages were coming out blank !
Wait for it !
The solution is so so simple !
As wordpad docs are only usually in BLACK.I decided to change the colour to blue and lo and behold it worked !
Simply my black cartridge was empty ! upon refilling Absolutely everything printed fine !
Sometimes the most simple solution we cannot see !
I hope this has been helpfull to you..............
Regards
Speedypete07
Posted on Aug 10, 2009
Brother MFCJ870DW Cuts Off/Chops Off/Truncates Left Side Return Address By About Half An Inch On #10 Com Envelope, Suddenly Started Happening
Check carefully that you have specified it to use the # 10 and that the format does not include a wide margin. If that fails, try printing the Return address 'right justified' and see what happens.
Feb 01, 2014 | Office Equipment & Supplies
Hello. I have a Mimaki JV33BS Plotter (1.6m print width). Suddenly as from couple of weeks ago the plotter started printing some black dots everytime there is an image or color to print. This dots are...
Sounds like a cleaning issue.
Drivers for your printer can be downloaded from here:
http://www.mimaki.co.jp/english/download/uc_index.php
Manuals available here:
http://www.mimaki.co.jp/english/download/manual/#jv33
You may want to review page 158 of the PDF of your Operation Manual with respect to Troubleshooting when Image quality is poor. This document points to a number of sections with respect to specific cleaning requirements.
Dec 22, 2010 | LG Office Equipment & Supplies
Normal color print ,black print cuts off top/bottom of letters
Suggest using the printer software utility to clean the print heads, then print a test page.
Nov 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
Print job stops in the middle of a print job
first if its happening from few days than go for system restore - start - all programs - accessories - system tools - system restore.. select that date on which it worked fine.. or else add printer and install deskjet 990c and than try
Oct 14, 2009 | HP DeskJet 722c InkJet Printer
Printing is off center on the HP 6540. The image or page being printed is cut off on the right margin and on the bottem of the page.
ok, most likely your printer cartridges are off. In order to fix this, you can use windows to align them. Click start > Control Panel > Printers and Faxes, and right click the printer thats giving you trouble. Then go to properties. Next, go to the services tab, and click align the cartridges, and continue from there.
Sep 01, 2009 | HP DeskJet 6540 InkJet Printer
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
Bottom of page is cut off sometimes printing from vista computer
Hi- I'll try to solve this.
Go to the start menu and open the Control Panel. Double click on Printers. Right click the L7580 printer and choose "Printing Preferences" On the preferences window click on the "Advanced" tab. Make sure "Advanced Printing Features" is set to "Enabled" Under "Printer Features" turn "Minimize Margins" to "On"
This should solve the issue. If minimize margins is off, it will cut it off at the bottom.
Feb 06, 2009 | HP Officejet Pro L7680 All-In-One Printer
Sato CL 480e not printing clearly...
Your platen roller (the black rubber roller) isn't smooth in that spot. Maybe it has be nicked or cut there or has something stuck onto it. If it's cut you will have to replace it, otherwise try cleaning it with high percentage isopropyl alcohol.
Jan 30, 2008 | SATO CL408e Thermal Printer
Using the cutter
you want to print borderless on a cutsheet media? you just have to select and 'cheat' the printer in the printer properties, in there choose roll on the paper source option then enable the cutter and choose double cut on printer's set-up menu on the panel, then it'll cut before and after the printing to make it borderless from top to bottom and from edge to edge. just be sure that the cutsheet media is long enough so that the printer can still hold the media as it finishes the printing or else it'll be a waste, cause the printer wont finish the image. and take note that the epson sp9600 has a limitation in printing borderless, it'll only print borderless on (12", 17", 24", 36:, and 44") media size only i think there's also 14". trust me it'll work, ive done it! :P
Sep 26, 2007 | Epson Stylus Pro 9600 InkJet Printer
HP DesignJet 488ca InkJet Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
