Question about Whirlpool Duet GHW9150P Front Load Washer
Washer not level
How do you level the duet washer?
    President:
  • Whirlpool Master
  • 2,651 Answers
Unit has four feet, to level, however, the "shock absorbers" with in the unti may have come undone, try removing the lower acess panel( 3 torx 20 screws) across the bottom front of unit, youl be able to see inside and posibly locate the broken shock(s)
Posted on Apr 23, 2010
Whirlpool washer F3 E1
F3E1 Error - Pressure switch/ sensor fault.
  • Your washer cannot detect the water level. Check the pressure sensing hose for kinks or blockage or the pressure sensor itself.
  • I won't leave you without a clue. Follow the link below and it will explain more than I can write here.
  • http://applianceassistant.com/Washer-Repair/Duet/Duet-Washer-Error-Codes
  • Jan 02, 2017 | Whirlpool Washing Machines
    WHIRLPOOL DUET WASHER THE WASH LIGHT IS NOT LIGHTING UP WHEN WASHER IS STARTED AND THEN I GET "LF" CODE
    LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
    Is water supply connected and turned on?
    Are hose screens plugged?
    Is water entering the tub? If so check pressure hose connection to machine/motor control.
    Oct 12, 2012 | Whirlpool WFW9151YW Duet 3.5 cu. ft. Front...
    Whirlpool Duet F11
    Seems that the fault is within the main control panel board. It can be due to failure of the drive relay or semiconductor within and might need a board level service or a replacement of the board.
    Jul 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    How to keep the floor from vibrating while in spin cycle
    Most likely cause of vibration is that the washer isn't leveled. Use a torpedo or carpenters level and adjust the support feet on the washer to get it level. If it still makes the floor vibrate, you may have a soft floor. You could then try putting a piece of 3/4 plywood under the washer to help support the weight.
    Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    How do I keep the front loader Duet Washer from knocking when its spinning a large (jeans) load?
    you have to balance it out. You need to open the lid and move the cclothes. Do not overload washer. Underneath there are little legs. Put a level on top of washer and then start screwing the legs down or up to make the washer level.
    Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Washer rocks and will not stay put. Perfectly level
    check to see if the shocks are broken, 4 of them. A service guy fixed mine with new ones
    Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Is there a way to increase the water level on a whirlpool front load Duet washer model GHW-9150
    If the machine is underfilling, check the water level switch. This diaphragm like device has a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the tube and when it reaches a certain level, it activates the switch to shut off the water and signals the timer to advance to the appropriate cycle. Make sure the plastic tube has no damage or obstruction. An obstruction can cause the switch to be activated too early.The switch can be tested for continuity using a multimeter or ohmmeter. A lack of continuity would indicate a faulty switch. Hope this helped and best wishes.
    Aug 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Water filling to washing level when washer is not being used.
    sounds as if you have a bad inlet water vavle, it doenst complety shut off after use, and waer will trickle in( adding up to quite a bit in a day) youll need to replace the water inlet valve(directly behind themachine where the hoses hook into). in the meantime turn off water inbetween uses
    Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Can i adjust the water level on my Duet?
    Sorry there is no way to adjust the water level. the washer decides how much water by how much clothes are in the washer .
    Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    112 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
