Ovens Logo
Ron Coons Posted on Apr 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ge double wall oven approx 4-7 yrs old ( electric) unit shuts down after intial preheat, clock remains on (so not losing power) but the ''bake 350'' dissappears , and am able to restart immediatly only to shut down again. has new clock and new sensor already.
Anonymous
Level 2:
  • Expert 523 Answers
  • Posted on Apr 24, 2010
Anonymous
Expert
Level 2:
Answers
523
Questions
Helped
134435
Points
944
Check the cooling fan in the back where the boards are clean the grate there
  • Anonymous Apr 25, 2010
    check the cooling fan to
GE Profile Wall Oven. I am testing the heating elements on a GE Profile JT952BF8BB and want to know what is the functioning range of the Ohm reading?
Question edited for clarity.
Question moved from Miscellaneous.
As long as you have continuity, they are fine, and it should be around 20 ohms plus or minus
JB968SK1SS GE Profile Issues - Bake Element/ERC/Sensor
Appliance Blog https://www.applianceblog.com > ... > GE/Hotpoint
Mar 18, 2013 - The broil element is about 15 ohms and the bake element is about 20 ohms so the two together will be around 35 ohms. Disconnect one of the wires ...
JB705DT1BB Electric range oven shuts down after preheat
Feb 26, 2017
FIXED - KEBS208SSS04 How do I remove bake element
Dec 3, 2016
More results from www.applianceblog.com
JTP15 Oven - Shuts down after preheating
It sounds like the module is momentarily losing power when the bake relay clicks off. Does it do the same thing when you use broil?
Post back with the complete model number and I will try to find the wiring diagram for it and we will walk through checking it.
Thanks/Mike
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 • GE Ovens
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
GE Wall Oven JKP13GOTBB Touchpad is "too sensitive"??
I don't see that exact model number listed. Check the model / serial number again. If the unit is not too old, you can probably get a replacement key panel which should solve your problem.
1helpful
3helpful
Top and bottom oven doesn't warm up.
we had a repairman come and he opened the electronic control panel and hit the "reset" on it and it worked after that. hope this helps. these ovens stink.
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Lower and Upper ovens not heating
they have a thermal fuse in them that blows if too much heat builds up in them they have an improved blower moter thermal fuze kit for them i suppect thats the promblem contact ge for improved kit and inst ins
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
