Question about Sony Handycam DCR-SR40 Camcorder
When on the camera the image in display is invert
When on the camera the image in dispaly is invert
    Champion:
  • 287 Answers
This is a common problem with the flip out display feature. Either the little image inverter switch is bad on the flip out screen unit or the flex cable unit going to the display is bad. Sometimes that switch can be cleaned ,but if it's the cable it will need replacement. This problem is a display issue however ,so if you can rotate the display in another postion to where you can use the camera you can still use it. It will not effect the recording made. I fix these all the time . Repairs run from $40 to approx $165. Larry's Electronics 916-362-8708 ledstiles@hotmail.com
Posted on Apr 23, 2010
Dim display for compaq evo n620c laptop
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 07, 2013 | Computers & Internet
Monitor dispaly picture for 3 to 5 second then display gone
From the description one of the inverter transformers have failed, located on the power supply/inverter board.
May 21, 2012 | Samsung SyncMaster 510N (Silver) 15 inch...
The screen is going black like its in sleep mode when i open it up
I had the same problem. While rebooting the laptop the screen would be on for a few seconds after it finished rebooting then the display would go black. If you looked very carefully at the screen you could see the image was there but there was no light behind the screen to make the image visible.
I removed the black plastic display bezel cover that goes around the edge of the display screen to check out the lights and wiring. I found a small magnet that belongs inside the display bezel had fallen out of it's slot in the plastic bezel and was stuck to the inverter pcb (printed cicuit board). To fix this problem I secured the magnet into it's slot inside the display bezel with a bit of glue. After fixing the problem and putting the display bezel back together the laptop worked normally.
This magnet is how the laptop knows the lid is closed. When the laptop is closed the magnet is moved closer to a magnetic switch on the inverter pcb and activates the switch. The laptop thinks it is closed and shuts off the lights behind the display screen. When the magnet fell out of it's slot and stuck to the inverter it activated the magnetic switch all the time whether the laptop was open or closed. This caused the laptop to think it was closed and shut off the lights behind the dispaly screen as soon as the reboot finished.
Jul 17, 2011 | Compaq Presario CQ61-310US Laptop
There is 3 phase power to the inverter. Motor is ok. There is no dispaly and power led is off on front panel. no short circuit in motor or inverter ( combivert f5)
If there is no LED or display the inverter is not being powered up. Most likely a defective power stage which would need to be repaired.
Nov 15, 2010 | Inverter KEB COMBIVERT F5
My camera will no longer show the image on the screen when I am taking a picture with my Canon PowerShot SD1000 digital camera. Can this be fixed or is it time for a new camera?
most likely you have turned the dispaly off. find the display key and turn the screen back on.
another option is to go into the menu, then go to display and set it there.
Jul 18, 2010 | Canon PowerShot SD1000 Digital Camera
Camera giving invertd image.
The camera displays an inverted image on the LCD camera screen or when you view the image on windows vista? If it is Vista what program are you using to view the image? If it is the camera check the settings on the camera for the special effects settings and see if the image inversion setting is on. Ther could also be a problem with the LCD display on the camera.
Sep 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
My hp dv 2000 notebook is not get any dispaly on screen
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 30, 2009 | HP Computers & Internet
I have a Sony DSC-F88 5.1MP camera... When you switch it on to any of the program modes - image dispalyed on LCD and photographed is distorted. Image is skewed with the edges of the image flaring with...
Your DSC-F88 has problem with CCD Imager and needs to be replaced. Good news is Sony will replace it free of cost. Click Sony Official website to get further instructions. Hope this info will helpful for you.
Aug 12, 2008 | Cameras
Negative/inverted pictures
If the images in the camera are inverted , then could mean repair or replacement is the remedy and I suspect only replacement will be the answer.
When you say Photo Gallery- do you mean as displayed in your computer after uploading?
If so then an image editor such Irfanview or Picasa will revert them.
Jun 23, 2008 | Fuji FinePix A350 Digital Camera
Camera on phone is inverted...
When you are in the Camera mode, press the Volume button down, that is to set the mirror image, the up button is for upside down or right side up Regards
Jul 29, 2007 | Samsung SCH-a930 Cellular Phone
Sony Handycam  DCR-SR40 Camcorder Logo
133 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
