Question about Apex Digital AT2708S 27" TV
My picture posisiton is not correct
The posistion of my screen is not posisitoned correctly on the screen, it seems as if the position is offset, I was wondering if there is a way to correct this.
  • 129 Answers
There is a way to correct it. Adjustment of the deflection yoke to a desired ratio. But have the job refered to a qualified person because you will need the unit working during adjustments.
chris
Posted on Mar 23, 2008
SOURCE:
Error u60
code u60: Job offset home position sensor does not detect home position for the Job Offset Assembly.
check
home possition sensor actuator
home posiition sensor
sns harness ... is there any damage or misalignment. replace broken parts.
if that did not help
Test the job offset home position sensor.
run the service diagnostics offset home position test.
Does the sensor function correctly?
If yes you well have to replace the engine control board. That will give you that error. Hope this helps if you need more help let us know at iteminconline.
iteminconline
Nov 04, 2013 | Xerox Phaser 7400/DXF Laser Printer
How do you correctly position the thermostat
I don't think it makes a big difference as long as the thermostat is not touching anything in the intake or the water outlet. You may have to turn it slightly to fit into the space, but the offset is for the tiny vent on most models. I don't think the 2.0 engine uses an offset style but the 1.8 might.
Jan 22, 2013 | 2001 Nissan Sentra
I can't start my 1998 chevy blazer I just put viper remote start in it started before
make sure you plugged in the toggel switch AND hooked the black/white wire to ground....and obviously that the toggle switch is in ON posisiton
Oct 12, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Engine won't turn over...replaced battery, still not starting. alternator checked out ok. how can you confirm if it's fuel pump?
Hello inspiredtouc, your fuel pump is located in the gas tank. Turn your key to the on posisiton, without tuning to start the engine, go back by the gas tank and listen very closely, you should be able to hear the small motor on the fuel pump. You do have to listen real close.
Good luck my friend!
Jan 16, 2011 | 1998 Ford Explorer
Image on LG 42PC5D-UL is off center toward right side of screen after replacing main board eax38589402 from LG 50PC5d-UL. Both boards have same part number.
You've got to go minto your main menu and in the screen position settings you will be able to correct the horizontal offset and the verticle offset. You'll also hve the option of resetting all values to factory default but, I would suggest the former first. Thanks, Dana
Jan 15, 2011 | LG 42PC5D Television
I have white specks on screen toshiba 65 in DLP
White dots on a DLP mean that some of the tiny mirrors on the DMD board have failed and are stuck in the on posisiton and always reflecting the white light from the lamp. The DMD on this model is not available sepratley so the complete light engine needs to be replaced. The part number for the light engine is 75006693.
Aug 28, 2010 | Toshiba 65HM167 65" Projection Television
I have a 96' F150 and it wont turn off.
Try spraying graphite in the switch. this may work but you will need to replace the switch
Dec 11, 2009 | 1995 Ford F150 Styleside Regular Cab
GPS position is offset from map location
This could be because your datum and your posistion format. Under your menu go to setup, then units and make sure you have the correct info set in there for your area. NAD27 Canada would be the one you are looking for. Give that a try and see if it works. If it is still off, consult the manuals that came with your topo and see if it says what datum it uses.
Nov 15, 2008 | Garmin 010-C0495-00 TOPO Canada - Manitoba...
Epson R-260 offset
Make sure you are using the correct version of the Print CD. If you had a older Epson printer with this program remove it, and install the one that is on the disk.
If you are operating on a Mac and it has automatically updated to the latest OS, remove and reinstall the program.
Aug 22, 2008 | Epson Stylus Photo R260 InkJet Printer
Convergence Problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
replace convergence ic
Oct 16, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Apex Digital AT2708S 27" TV Logo
110 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
