Question about Whirlpool Duet GHW9150P Front Load Washer
What is F 2???
This is DRIVING me CRAZY!!!
I wash clothes and it gets to 2 minutes left and then STOPS and comes up with F 2 and water still in my washer?
I'm lost and have no clue how to get this working NOR my clothes clean now! PLEASE HELP
  • justcheryl Mar 23, 2008
    Nears end of cycle and gets :F: on screen and will not proceed despite my most diligent efforts to statt it up;;;;;
  • 8,617 Answers
This is what the code F2 means for whirlpool duet washer.
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is
flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes
Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is
running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Mar 23, 2008
Why is the water level so low? In my machine the water level is so low that all water is absorbed by the clothes and no water is noticeable around the clothes.The machine fills water for 1 minute. Bot
If you have a brand new machine with a little pimple of an agitator in bottom of tub, these are the new water saving models. You will have to get used to it. This new and improved design is driving people crazy. If this is an older machine your inlet water valve is clogged probably due to hard water. You can clean out, or replace. GOOD LUCK FRIEND.
Nov 05, 2014 | Whirlpool Washing Machines
Whirlpool Calypso stops at 26 minutes and throws ob code
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Fisher Paykel washing machine not working properly
It's most likely the Lid switch (reed switch). Does it come up with a fault code or beep at all? if so there are eight LEDs reply with the lights eg 00100010 1=on 0=off cheers
Mar 24, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
Nov 23, 2008 | Hotpoint Aquarius WD640 Front Load...
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Front Load Washer - Error F30
hI I HAVE REMOVE THE TOP COVER. YOU WILL SEE AT LEFT A PLASTIC ACTUATOR WHO MUST BE UNPLUG FROM ANOTHER PLASTIC PIN. JUST PUT IT BACK TOGETHER AND THE PROBLEM WAS GONE!
Jun 16, 2008 | Washing Machines
Creda machine won't agitate with clothes in it
Your load is prob to heavy for the older washer. it just doesnt have the power to handle it no more. time to replace it, sorry.
Jul 30, 2007 | Creda W120VW Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
193 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
