Question about Dell 3010cn Laser Printer
A black streak is appearing mid-page of my copies. Could this mean that the drum cartridge needs replacement?
DJYar
  • 41 Answers
SOURCE: black streaks on printout page
It sounds like excess toner has built up in or around the imaging drum. I would *carefully* remove the toner and drum (can be messy) and use some canned air to clean the inside out. If you are still getting these streaks, it might be time to get a new drum (DR 400) as you are supposed to replace the drum every 6 to 8 times you change the toner cartridge.
Posted on Aug 23, 2007
SOURCE: streaks on left side
Hi
Solution here
http://www.dellcommunity.com/supportforums/board/message?board.id=A940&thread.id=22414&view=by_date_ascending&page=1
Yop
Posted on Feb 12, 2008
SOURCE: STREAKS WHEN PRINTING
IN MY CASE THE PROBLEM WAS A FAULTY DRUM. I HAD ORDERED A NEW ONE AND THOUGHT IT SHOULD FIX THE PROBLEM. IT DID NOT. I CALLED THE COMPANY AND THEY SENT ME A REPLACEMENT. WHA-LAA!! PERFECT PRINITING AGAIN...
Posted on Mar 16, 2008
  • 47 Answers
SOURCE: HP laserjet 3030 black streaks
You have useful help if you measure the distance between the defects. If the lines are repetive, use this link http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=378048&prodTypeId=18972&prodSeriesId=378048&objectID=c00063561
Posted on Nov 05, 2008
yooperbud
  • 8637 Answers
SOURCE: Streaks on photo sensitive drum HP laserjet 5MP
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
We have a HP LaserJet 1320 printer that is leaving black marks or streaks on the paper-maybe ghosting(?). We have switched cartridges and it is still appearing. Any help would be appreciated!
Vertical lines, ghosting, streaks, and dots usually indicate a problem with the fuser when it doesn't regulate temperature correctly. When this happens the toner sticks to the drums and then copies the impression on successive pages, or gets scratched by the sand papery build up making lines as each sheet goes through.
Horizontal lines, page dusting, and vacant areas on the page are usually the toner or the drum, which on most printers are one unit.
If you have replaced the cartridge and the problem didn't go away, you probably have to replace the fuser.
Apr 27, 2010 | HP LaserJet 1320 Printer
Severe lines appear on copies. The cartridge is
Most likely it's the toner cartridge. Remove the cartridge, turn it over and slide open the cover over the drum. The drum is the colored cylinder running from one side of the cartridge to the other. Do you see what appears to be the same streaks going around the drum? The drum should be completely clean and free of any lines or streaks. If it has lines or streaks then the cartridge is bad.
Only other possibility here would be the scanner glass. Make sure your streaks don't go away when making a copy from the glass. If they do you could have dirt or trash on your scanner glass.
Good Luck and thank you for using Fixya.
Mar 11, 2010 | Dell 1600n All-In-One Laser Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
I have a BROTHER MFC- 8860DN that makes black streaks on copies
If this is only happening with copies and not straight prints, it is possible that the problem is with the scanning unit. Use the soft cloth to clean the scanner area to the left side of the machine where pages are scanned when run through the page feeder. A spec of dust or other debris in this area will appear as a streak along the length of the page.
If it occurs on all prints, You may need to replace the drum or clean the fuser unit.
May 29, 2009 | Brother MFC-8860DN All-In-One Laser...
My canon ir4570 has been working fine till now. Black streaks appear at the bottom of the page. How can I get rid of the black streaks?
Hello dear; I believe that's drum cleaning blade cause the problem you may replace drum cartridge or drum blade.
Apr 29, 2009 | Canon Office Equipment & Supplies
Streaks on left side
REPLACE DRUM CARTRIDGE THE CLEANER BLADE IS BAD
Jan 20, 2008 | Dell 3100cn Laser Printer
Large grey streak down center of page
It is the fuser at rear giving you grief! The upper heat roller has a teflon coating that wears away allowing toner to stick to roller and smudgin prints as they pass threw it. The fix is to replace fuser assembly, take to brother dealer to fix.
You can prove it to yourself by timing the print to stop mid way threw machine then remove print cartridge and look at paper, you should see a image is good untill it hits the fuser,( pre fused image "rubs off" paper.) If you have changed drum and toner thats all it can be. They all do it in time.
Fuser is hot bit at rear, pull out drum and look in the back with a small torch you will see upper heat roller is worn, guestimation $90 for fuser plus labour to fit.
Nov 16, 2007 | Brother IntelliFax-2820 Laser Fax
Black streaks on printout page
Aug 22, 2007 | Brother HL 1440 Laser Printer
Dell 3010cn Laser Printer Logo
24 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
