A squealing noise during the sensing cycle of your Maytag top-load washer can be caused by a number of factors. Here are some common reasons and steps you can take to resolve the issue:
Loose belt - The noise could be caused by a loose or worn belt that needs to be tightened or replaced. You may need to remove the front panel of the washer to access the belt.
Idler pulley - If the idler pulley that keeps tension on the belt is worn or damaged, it can cause a squealing noise. Replace the idler pulley if necessary.
Bearing - A worn bearing in the tub can cause a squealing noise. Replacing the bearing will typically require disassembling the washer.
Drive motor - If the drive motor is worn or damaged, it can cause a squealing noise. Replace the drive motor if necessary.
If you're not comfortable diagnosing and repairing the issue yourself, it's best to contact a qualified appliance repair technician for assistance.
when in spin out cycle when first comes on makin a noise like something is in the pump i check it and the pump is clear must be maybe lower bearing assembly sounds like something is lose or broke it also stops instancely at end of cycle what could this be
Please keep in mind, I'm attempting to diagnose your unit without being there and with very little information.
From my experience, I would think you have a bad belt. They get stretched over time and start squealing in the spin cycle. If you don't change it, it will make a noise in every cycle until it comes off. NOTE.
When changing belt. Check and be sure the pulleys have no play on their shafts. They also go bad. It's better to fix it all now than one to have to repair four or five times this year. Good luck!
Please rate solution
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. for detailed help with diagrams and step by step instructions click the linkhttp://www.applianceaid.com/washerspinnoise.html
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
My washer did the same thing. I put some belt dressing on the belt (the belt is on the very bottom, no disassembly rquired). The belt dressing I picked up at the local auto parts, and this seemed to help.
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out.
Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced.
Good luck !!
