Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Port in front for oil and the back is for gas and mixture
I own a homelite chain saw I just brought powerstroke 23a it has two port holes the one in front that is were the chain oil go right. The one in the back is for gas and 2 stroke mix I belive I put The 2 cycle oil in the front it cranks but the chain is not moving fast threw rotation I pour the oil out but it smoke bad is that just the oil burning off. Thanks Andre crazy question but it happen
    President:
  • 2,220 Answers
Hello Andre;
I think you are saying you put oil/fuel mix in the oil tank and bar oil in the fuel tank; discovered your mistake drained both tanks and refilled with the correct fluids. Now the saw runs but smokes excessively. I think it will do no lasting harm. After you have run a few tanks of the correct mix (50:1) through the saw. Remove and clean the muffler and spark arrestor, reinstall them. Inspect your plug if any evidence of fouling replace it. I think you will be cutting with this saw for years.
Yes the additional smoke is caused by a very oil rich mixture and should abate with each fresh tank of fuel. If the chain is not moving ensure the chain brake is not engaged.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 23, 2010
Testimonial: "Thanks a million Andre"
CHAIN SAW HOMELITE FUEL
You should run your saw at 25:1
More tips and advice on different makes and model chainsaws here
Sep 15, 2012 | Homelite Garden
I'm trying to find the fuel/oil (50:1 etc.)
Yes, it's 50:1 which is 2.5oz. of 2cycle oil to 1 gallon of gas
Jim
Aug 14, 2011 | Homelite Garden
What is the gas-oil mixture for Homelite 360. It is about 25-30 years old.
chainsaws are 40:1
3.2 oz 2-cycle motor oil per gallon gasoline
Oct 26, 2010 | Homelite ZR10926 16" Chain Saw
I need to know the amount of oil to mix with one gallon of gas for 18 inch homelite chain saw
You need to mix 2.6 ounces of 2-cycle oil (NOT motor oil) with one gallon of fresh gas to get a 50 to 1 mixture. Most 2-cycle oil is sold in small bottles this size and have directions on them to get the correct mixture.
Sep 09, 2010 | Homelite Garden
Do not know what mixture or how to use
40:1 mixture for the fuel:oil ratio.16:1 will cause your saw to barely run(if at all) and if it does, will fog out every mosquito for 4 blocks. You can use any reputable 2-stroke oil, though stay away from outboard engine oil. Get the good stuff that says Stihl, or Husquavarnah, or something like that. Even the Homelite stuff is ok. The oil tank takes regular bar and chain oil.
May 30, 2010 | Homelite ZR10926 16 Chain Saw
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Want to fine gas and oil mixture ratio for Homelite 16 inch 33cc
Oil Mix Ratio:
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Stihl & Tanaka; all recommend 50:1.
McCulloch & Poulan; recommend 40:1.
Chinese chainsaws recommend 25:1.
Lou
Apr 25, 2010 | Homelite ZR10926 16 Chain Saw
I have a homelite chain saw that the bar oil is not dispenseing
May be oil port on saw clogged. Remove side cover, remove bar and chain. Remove giude plate if equipped. Check to see if small oil hole on saw is open and clean. You can start the saw with side cover removed to see if oil is coming from oil hole or not. If it is coming from oil hole when running the problem is most likely dirty bar .If bar is dirty check to see that groove is clean and the oil hole along the edge of bar is clean also. The hole is at same end of bar that attaches to saw.
May 08, 2009 | Homelite Garden
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
172 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
