Question about Cell Phones
My lg3610 is not catching network how can i fix it
  • 713 Answers
Hi,the network problem you are encountering with your phone might be as a result of network band selection problem,or probably there is a loss of connection between the antenna and the band interface,
However,the solution provided below will help you in order to fix the network problem on your phone;
1. You have to observe the handset if it has to do with setting the network band for the appropriate subscriber required of the phone.
2. If it is phone that has up to three network band you select them one after the other to get the appropriate band for the subscriber, you them register it.
3. Check if the antenna is touching the board interface, if not do so by soldering the antenna to the board interface.
4. Take a close look if anything is removed or pull off from the network area board e.g. chips, capacitors, IC diode etc.
5. Check if any resistor or chips are not soldering very well then you solder them,with the help of a soldering iron.
6. If not still, you service the board by partial washing and heating,you can heat with the help of light bulb in an enclosed box.
7. But you must ensure the board is cool before you must couple it.
8. If no still network you can rewrite the program by means of software.
Thanks and take care
Posted on Apr 23, 2010
Tip
No Network - Cell Phone
Today, i would help you to Fix a Common issue with Most of the Cell Phones - No Network.
The below mentioned Points should be Considered to Fix this :-
1. The First thing, i have Found with most of the Handsets is that they are LOCKED. Make sure that the cell phone you are using should be Unlocked. In case, it is Locked, Contact the Original Service Provider and get the Code to Unlock or you could Search Different Sites who claim to Offer that ( Note - I never used any Site and i am not aware whether it would be Hit or Miss ).
2. Make sure that there could be a Signal Problem. There are Cases, when you Cell Phone could Read ' Emergency Only ', if there is No / Less Network in that Area. Try to Use it away from that Place. If that is the same problem, then you need to troubleshoot the Cellphone.
3. Have you tried Setting it for Manual Network. In Most of the networks, Automatic Network Search is Set as Default. Change it to manual and Search that. Usually this would work on most cases.
4. Network catching Capability also Depends on the Handset. No two Handsets could have the Same Capability. You could try to Use ' Network Boosters ' which is available with most of the Online Vendors or Local Shops.That could really help the cellphone to Catch Network.
5. If it still shows Message like ' Emergency Calls ', then it could be a Defective Antenna. Take another Set ( Same Model ) and Compare, is that an issue with Both Sets or Your Set. If that is Only with your Handset, you need to send the Cell for repair.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
on Jan 20, 2010 | Cell Phones
Network is not catching ........ and it tells no network found. wen v search for a network
i need to tri sim mobile(Lephone) network is not catching ........ and it tells no network found. wen v search for a network please rectfy my problem
May 22, 2011 | Health & Beauty
Network problem
hey hi buddy...
this is not a big work,just switch off phone and take sim card out and re insert your sim again to the phone ...sometimes it happens due to network problem also..even after trying this if it does not catch the network,then go to settings,phone settings,network settings and change the network selection mode to manual an d see that the network you are using is being displayed or not????if it does not catches any network then the fault i with the phone,or if it catches other network and only the network which you use is not being displayed,then the problem is with the network.......
of fault lies with phone you can update or re install the software from nokia care....
thank you........good day
Sep 22, 2010 | Nokia 5310 Cellular Phone
Ma NOKIA6600 doesnt catch Signals correctly, Can anyone fix it?plx
A phone can't catch signal correctly if your in a remote areas where cellphone sites are not available. Try going out of the house and see if the signal strength is going good. There maybe interference and call also the network provider of your phone. Get to know if there having technical problems with there signals. Another thing, if none of this works, I suggest you go to a cellphone repair center and let a qualified technician handle it.
Dec 14, 2009 | Nokia 1600 Cellular Phone
My contact no is 9718090496 this no. is not catch
select (settings) option (select network) option and then select (manual) ....wait for few minutes..try for some time and select ur network....
Nov 07, 2009 | Sony Ericsson K200i champagne on Orange...
No signal
Signal usually depends on the network and mobile as well. There is nothing you can do, if the signals are not there. If you are in basement or a place where the tower is not available, this might be an issue.
The only thing that you can do, either to use a better mobile ( Some sets have this ability to catch good receptions, even if the signal is low ), or you can use network boosters.
Network boosters are easily available online on many sites like
http://www.ebay.com
or you can find that by googling yourself.
However, network boosters are not 100% hit.Only 5% success rate is there.
I hope this would help you to fix the issue.
Thanks for using Fixya.
Apr 28, 2009 | Cell Phones
NO NETWORK
HI,
YOU GOTTA CHECK YOUR SIM CARD 1ST.AND ALSO THE LOCATION WHERE YOU ARE,TO MAKE SURE THAT NETWORK SIGNALS ARE COMING, CHECK ANY OTHERS CELL OF SAME NETWORK.IF YOU HAVE ANY OTHER NETWORK'S SIM.CHECK IS IT CATCHING SIGNALS ! IF THE PROBLEM PERSIST THEN YOU SHOULD GO TO MOBILE ENGINEER.(CUZ IT WILL BE YOUR MOBILE'S NETWORK SIGNAL IC'S FAULT).
Oct 28, 2008 | Nokia 2610 Cellular Phone
Z310a
You need to hvae te phone's frimware reflash, you can do this online at topsony.com or take the phone to a mobile center and have them fix it for you.
Sep 01, 2008 | Sony Ericsson K800i Cellular Phone
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
