Question about Microwave Ovens
Ge model jvm 140 complete loss of power. all lights are out. there is power to receptale
  • 443 Answers
Not an easy situation when it's mounted above the range,it will have to be taken down,remove the outer case and look for any and all fuses, it sounds like you have a blown fuse or if they all look good you may have a bad power supply or bad control board.
If it isn't the fuse I am not sure if it would be worth the investment to get it repaired, you may be better off to replace the whole unit?
Good Luck !
Posted on Apr 23, 2010
Testimonial: "it was the fuse. cost .98 cents Thanks bill"
What replaces model jvm 1630 wj microwave
JVM models should be a GE NOT A WJ
Feb 13, 2018 | Microwave Ovens
I have a GE SpacemakerXL Microwave Oven Model JVM 1350 The fan and the light works, but the microwave is not working and the screen says
There are two possibilities, one of the door switches has malfunctioned, usually caused by food partical buildup, more than likely. or there is an issue with the microprocessor control board, less likely.
Mar 11, 2012 | GE JVM1350BW/WW/AW/SY Microwave Oven
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
Microwave Oven has no power.
yeah open the microwave, and you will see a fuse usually located on the top area. the is also a fuse around the back of the panel area.
Jul 02, 2009 | Microwave Ovens
My GE spacemaker JVM 1440 Watt microwave has F4 error code.
Have GE JVM1440BH light and fan that are operated by the touch pad do not work. Both stop working at the same time. Ideas????
Mar 21, 2009 | GE Microwave Ovens
No power to GE Spacemaker Microwave
I have model GE Microwave serial # JVM2070SK02. I start to cook something and it shuts off 5~10 seconds. Keyboard is still lit up, but no clock, fan, light and you cannot operate anything on the key pad. Unplug the unit and it resets. Sometimes it cooks, sometimes it doesn't? It is getting more frequent with the shutting down problem?
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Jan 22, 2008 | GE JVM1650 1000 Watts Microwave Oven
Light Bulb Replacement On JVM 1860SF001
You can find an exploded view diagram by entering your model number (without the space) here: http://www3.sears.com/ That diagram may help.
Mar 23, 2007 | GE JVM1860 Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
