Question about Jensen JMP-13A Consumer Microphone
No sound microphone does not work
I had my mcirophone installed with XP. I am now running Windows 7 but my microphone is not working
    Genius:
  • 1,550 Answers
Check the audio drive maybe are lost when you change the sistem
Posted on Apr 23, 2010
ConnectLand cl-me 606 goose neckdesktop microphone to desktop
Look for a 3.5 mm microphone port on the computer. Usually the port on the back of the desktop will have a pink surround. (There will be other ports there; the usual minimum are the green port for speakers and blue one for line-in.) Put the 3.5 mm jack on the end of the cord on the microphone into the port. If you have an add-in sound card, use the microphone port on the sound card.
Some machines will also have a front panel microphone port. This will have a small mike icon next to the port.
Next you need to ensure that the audio device is set to Microphone. For Windows systems (Vista/7/8), enter the Control Panel and go to the Hardware and Sound panel. Click on Manage Audio Devices under Sound. Then click on the Recording tab. Check if the microphone listed as plugged in. Make this the default recording device. (XP has a slightly different name for the panel.) For XP through Windows 7, click on the start button and then find the Control Panel listed on the right. For Windows 8, from the desktop, press the Ctrl and X keys at the same time. Then find the Control Panel in the list. (Alternatively, activate the Charms menu, Ctrl+C or hover on the upper right of the screen. Move down and click on the gear (Settings). Then select the Control Panel.)
If the computer doesn't indicate that the microphone is plugged in, make sure that the 3.5 mm plug is in the correct port. Next try the microphone on another computer. The audio card port could be damaged or the microphone cable could be faulty. If the microphone works on another computer, you can try a USB audio adapter (StarTech ICUSBAUDIO or similar) or a new sound card. (Note: some older sound cards do not work properly on newer versions of Windows. If you have a sound card installed and the motherboard has an on-board audio device, remove the sound card. Enable the on-board audio in the computer's BIOS. Install the appropriate audio drivers. Try that audio device. Accessing the BIOS will depend on computer. Often you can press Esc, F1, F2, F10 or Delete repeatedly after you turn on the computer. If Windows starts to boot, turn off the system and try again.) If another computer doesn't recognize the microphone, I'd recommend a new microphone. Fixing the cable isn't worth the effort.
I hope this helps.
Sep 20, 2013 | Computers & Internet
The microphone worked last night on skype, tonight nothing.
Go into Skype sounds setting and make sure the microphone is turned on then go to the computer sounds settings and make sure the microphone is turned on.
Sep 26, 2012 | Microsoft LifeCam HD-6000 Web Cam
I have a Compaq V3228 AU model laptop. Windows XP is installed and everything works fine except for the built in mic. The built in microphone is barely audible. It works, but i can barely hear myself if i...
Turning on Microphone Boost in Windows XP:
Not all sound cards support Microphone Boost. The simplest way to find out in Windows XP is to open the Windows Volume Control. If a speaker icon speakericon.gif is displayed at the lower right hand corner of the Windows Desktop double-click it. If no speaker icon is displayed then click the Windows Start button and select "Run..." In the Open box enter sndvol32.exe and click the OK button. This will open the Windows Volume Control. Select "Advanced Controls" from the Windows Volume Control's Options menu. You should see an "Advanced" button near the lower right hand corner of the Windows Volume Control screen. Click the Advanced button. If the "Advanced Controls for Microphone" screen shows a check box for "Microphone Boost" then check that box and click Close. Now try making a test recording and see if it works.
Now, If you do not find this option, I found an amazing video that might just do the trick. Click on the
link and view how to see the hidden "Mickey" :). Mic Boost.
Jul 13, 2011 | Compaq Computers & Internet
My Samson Gtrack USB microphone works fine on another machine running windows xp and Ubuntu. However on a machine running windows 7 the microphone seems to be disproportionately sensitive and produces a...
This sounds more like an issue with the sound card or on-board sound module that is not properly grounded or the microphone is too sensitive (i.e. pulls to many ohms from the sound card). You may want to look for updated audio drivers for that PC or use an external USB sound module that is usually much better quality and inexpensive.
Mar 02, 2011 | Computers & Internet
Can i install windows-xp on my laptop which is currently working on windows-7 and use both of them.
Yes you can install windows xp in windows 7.
Windows XP Mode is a virtual PC image of Windows XP Service Pack 3 that could be run on Windows 7 Professional, Enterprise or Ultimate versions. Applications installed into Windows XP Mode could be run in Desktop Mode or Seamless Mode. In Seamless Mode, applications appear to run natively within Windows 7, but they are actually running inside the Windows XP virtual machine. Windows XP Mode might also provide additional integration that traditional Virtual PC images might not be giving. Applications installed on the Windows XP image could be exposed to the Windows 7 Start menu. Applications run in seamless mode is having automatic access to the Windows 7 known folders like Documents, Pictures, Desktop, Music, etc. Also the Cut-and-paste is enabled between native Windows 7 applications and those running in Windows XP Mode. Applications running in Windows XP Mode might also access your Windows 7 network connection and USB devices.
Nov 30, 2010 | Computers & Internet
My microphone was working fine on Windows XP OS. But after Windows 7 has been installed on my laptop, the microphone does not work. Please help
Try to look for a microphone specific driver for your laptop from the manufacturer or Microsoft.com site.
Otherwise, you may be out of luck, unfortunately.
Aug 19, 2010 | Computers & Internet
Toshiba mic not working with Win 7. I have a Satellite M305-S49052 Toshiba laptop. I have had the laptop for a little over a month and bought it new. I had been using Skype over that month and my...
It sounds like a driver or hardware incompatability issue. Go to the Toshiba web site and see if they have updated Windows 7 drivers or other support for your system first.
Second, you may be able to get the mic to work using the Windows 7 compatability mode which mimics Windows XP.
Dec 11, 2009 | Office Equipment & Supplies
Gigaware microphone 33-124 no sound with Windows XP SP3
Does it show a message like "unknown device" in winXp? then probably it needs an installer in order for a device to work properly, but if its working in the other computers running winxp then probably your own computer you are using have a problem with the usb ports on it. Hope this could help..
Oct 23, 2009 | Computers & Internet
Running digi 001 on windows 7
i got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
- veikko-antero
Mar 17, 2009 | Digidesign Mbox 2 Barebone
Jensen JMP-13A Consumer Microphone Logo
152 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
