Question about Brother SE-270D Computerized Sewing Machine
The gear thread feeder retaining ring keeps flying off. My husband is a copier tech and knows how to install this part but, after he does and I send each needle to home position, I can get about 100,000 stitches before the ring pops off. My machine is an Amaya XT. Can you give us any ideas?
  • 1 more comment
  • Kari Savelesky
    Kari Savelesky Apr 23, 2010
    the main concern is that there is friction or binding up on the gear that is causing the ring to pop off. The tech support that came with my purchase of the equipment says that the problem that I have only occurs if the ring is spread too wide upon insertion or the gear shaft is damaged. My husband has been a copier tech for 28 years and does work similar to this on a daily bases. He says that it is not either one of those things. Thank you for letting me pick your brain.
    Kari
  • Kari Savelesky
    My gear thread feeder ring is popping off. It has been installed correctly twice but, my husband (a copier tech for 28 years) says that there is pressure or something that the gear is hitting on to make the ring pop off. I have an Amaya XT. Tech support (for my warranty) has said that this is usually due to improper installation but, the retaining ring has been installed properly. Can anyone help?
    Kari
  • Kari Savelesky
    Kari Savelesky Apr 24, 2010
    We will replace the shaft and go from there. Thank you for your help.
    Kari
    Guru:
  • 415 Answers
You have one of two things that is the problem:
either your retaining ring is worn or slightly warped enough that is not making a tight enough fit OR the groove that your retaining rings slips in is worn and preventing a tight fit.
A good starting point is to take the retaining ring to a hardware store or a machine shop and have them match it up (assuming you have the original ring and not a replacement already) and get a replacement ring. This should take care of your problem. If you have already replaced the ring, you should verify from the manufacturer that you have the right size ring....or try a different size.
I do hope this information is found to be helpful to you moving forward.
Posted on Apr 23, 2010
  • 10,865 Answers
Hello. When the ring is installed use a product called loctite threadlock, available at any hardware store. Joe
I have a brother cs-8060 sewing machine but I don't have the manual for it. When I start to sew the machine makes a loud sound the and woont sew normally and then I get an E6 flashing on the machine.
An E6 error indicates a thread tangle. Combined with the noises you are hearing my guess would be that the tangle is around the take-up lever pivot and is seizing the machine (causing an overload - hence why it won't sew). The origin of this is often a further thread tangle between the tension disks, which has allowed the thread to fly loosely around the take-up. Your best bet will be to take it to your local sewing centre. This is the sort of issue we commonly address as a part of servicing. You will find a description of what you might try in the Service Centre section of our shop's website http://www.kornacraft.com.au/sewingcentre-under-the-covers/
Feb 06, 2015 | Brother CS-8060 Computerized Sewing...
Find free manual for white japanese sewing machine model #1010
check this link & see if it's the manual you need
http://www.singerco.com/uploads/download/738_white-445,988,999,1010-x.pdf
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
the feeder bar, do you mean the feeddogs, that are in the needle
plate?
for the feeddog part try sew4less.com
Aug 14, 2012 | White Sewing Sewing Machines
Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Feb 16, 2010 | Singer Sewing Machines
Feeder not moving thread is bunching up How do
I took off the foot, plate and where the bobbin is kept. Cleaned it out and there was a thread that was caught there. I put it back together and it worked fine.
Thank you
Patti
Oct 29, 2009 | Husqvarna Freesia 415
Needle not picking up bobbin thread. Seems threaded properly. lsd-1 (classic) Problem occurred after needle hit something perhaps the the cap spring which had some marks on it but no real damage. ...
change the needle, if bent it may skip, use top thread while holding to pull thru, turn bobin around to turn in oposite dirrection, bobins usually turn in 1 correct dirrection
Sep 28, 2009 | Sailrite Sewing Machines
The top thread keep breaking. should the tension
Thread breakage is usually due to the needle in backwards, upper tension too tight or old/weak thread.
When replacing the needle, make sure that the flat side is to the right (3 o'clock position) and is pushed all of the way up before tightening.
What brand and weight of thread are you using and are you sewing with the foot or free motion sewing?
Jun 17, 2009 | Juki TL-98Q
Need instructions on threading singer pixie sewing machine
i need help too i bought this machine for my 9 year old daughter i thought she was just breaking it bieng so young and inexperienced but my husband and myself have tried also and the same problem accured i tried to follow the instructions but they are so very hard to follow can someone please help me? I keep threading the machine the needle and the threading the bobbin but i get half a stitch and it breaks again. Does
anyone know what im doing wrong?
Apr 24, 2009 | Singer Sewing Machines
Thread breaking during sewing on Ericco sewing machine
replace the needle, use a heavier thread, insure the material is advancing properly as you sew.
Feb 08, 2009 | Singer Sewing Machines
Thread keeps gathering from the bottom, jams then breaks needle.
The burr is NOT good for sure, most parts on a machine can be replaced.
Troubleshooting and tech support for your machine from the manf.
http://welcome.solutions.brother.com/bsc/public/us/us_ot/en/faq/faq_top.html?reg=us&c=us_ot&lang=en&prod=hf_ls1217eus
In case you need the manual
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/model_top/HomeSewingMachine/hf_ls1217eus.html?reg=us&c=us_ot&lang=en&prod=hf_ls1217eus
Dec 31, 2008 | Brother LS-1217 Mechanical Sewing Machine
Brother SE-270D Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
