Question about Electrolux Dishwashers
Electrolux ESL 499 - display A
I have Electrolux ESL 499 integrated dishwasher. When a program is selected( no.3 ), off it goes and then 5 or 10 minutes in, it stops and an A is diplayed in the LCD display.Last time it was overfill filter problem Pls help.
  • 641 Answers
SOURCE: error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Posted on Jun 27, 2006
  • 1314 Answers
SOURCE: Electrolux ESL 6225
before you operate the dishwasher get your water as hot at the sink as you can this will prevent filling the dish washer with cold water and i would use powder or liquid now if you not sure of your heating element turn your washer to dry close the door for about 2-3 minutes get a glass of cold water open the door and pour water on the element if it sizzles its working
Posted on Feb 12, 2008
SOURCE: electrolux esl 6251 built in dishwasher 2 years old
PROGRAM WONT RESPOND MACHINE NOT STARTING
Posted on Apr 11, 2009
  • 3 Answers
SOURCE: Diplomat ADP8352 Integrated Dishwasher
I have the same issue how did you fix it?
Posted on Aug 13, 2010
SOURCE: I have an Electrolux Dishlex
hi peter, according to manual book -10 is not filling water fast enough. check inlet hose and valve, check pressure switch and pressure SW hose and clean sump filter which located bottom of tub that plastic strainer and stainless mesh clean them spotless. sometimes caused by this filter block the water passage and change pressure sw's leadings. and clean sump as well. b4 suspect PCB this filter cause many problem like not heating water, doesn't keep water. if dirty filter is the one you will save at least $300- for service man to come out and change the PCB for nothing. I think clean the filter doesn't hurt anyone.
Service Man K
Posted on Oct 16, 2010
Model ESL 499. Why doesn't it start?
You have activated the delayed start function. Please read following instruction from user manual.
8. Delayed Start button
Allows the start of the programme to be delayed by a minimum of 1 hour, up to 9 hours. How to set the delayed start When the button is pressed, the number appears in the display (4). Press the button again to select the number of hours by which you wish to delay the programme start, up to a maximum of 9. E.g.: if you have selected number , the wash programme will start in 2 hours' time. To cancel the delayed start set, press the button until the number appears. Close the dishwasher door to start the countdown: a long audible signal (about one second) informs you that the function is active. If you open the door again you will see, in the display (4), how long there is to go (in hours) before the programme starts. A flashing dot in the digital display means that the delayed start function has been activated. Opening the door has no effect on a countdown which has already been started. If, during the countdown, you wish to see the programme number selected in the display, press the Programme Selector button (5). If, after having started the countdown by closing the dishwasher door, you wish to cancel the delayed start, press button (9) (Cancel) for about 2 seconds until the short «instruction accepted «signal is heard».
Dado
Sep 16, 2015 | Electrolux Dishwashers
Electrolux esl 6226 not working beeping sound and light flashing
Hello Eamonn, I am happy to assist you!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Oct 12, 2013 | Electrolux EWDW6505GS Fully Integrated...
Electrolux dishwasher esl 6114 door does not lock
Hi Peter Gumbrell - Often when the dishwasher door does not lock, it is because the of door lock assembly. The door lock or latch may either be faulty or damaged. If I was in your position, I would personally recommend consulting a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Mar 20, 2013 | Electrolux Dishwashers
What does the shower and bar smybol mean on my ESL 63010 Dishwasher please?
I've been dealing w/electrolux for over 2 years on a dishwasher problem. Technician have tried all that they know & the dishes still come out dirtier than when they go in. I've been using it as a drying rack. Kinda exspesive drying rack. Electrolux won't stand behind their product either.They are offering me a 60% discount on a new Elextrolux dishwasher! Are they kidding?
Apr 01, 2011 | Electrolux Dishwashers
It fills with water and then continues to wash but the water does not heat up.the program does not progress.electrolux esl 6114.
Problem is either a bad controller board or bad heating element.
You will need to know how to diagnostic service work using a volt-ohm meter, and be mechanically handy if you want to diagnose and repair.
Dec 11, 2009 | Electrolux Dishwashers
Dishwasher not working properly
I have trouble with only the top not cleaning properly and have found blockages in the spinning jets at the top, may be worth checking
Mar 02, 2008 | Electrolux 23 in. ESL624 Built-in...
Electrolux ESL 6225
Feb 12, 2008 | Electrolux 23 in. ESL624 Built-in...
Dishwashers Logo
270 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
