Question about Sony KP-51HW40 51" Rear Projection Television
Sound but ni picture
After leaving the tv on for quite some time the picture will come in clear but until then there is only sound. some friends have recommended changing the projection bulb. i'm at a loss.
  • nars May 18, 2008
    I HAVE A TOSHIBA REAR PRO MODEL 40WH08B SOUND BUT NO PICTURE ADVICE ANYONE THANKS
    Problem Solver:
  • 30 Answers
I dont think that TV has a bulb it uses CRT's
You cant get CRT's any more. Sounds like the capacitors in the power supply are week and are takign time to charge thats why it takes a while to get a picture.
Not worth fixing
Posted on Aug 01, 2008
SOURCE:
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
White horizontal lines covering picture on Toshiba 51HC85
The set uses a Hyper board inside that processes all signals, it is well known for this issue, board no longer available=reason is quite simple : about a dozen tiny surface mounted filter caps on that board with age dry out, at first it will work after warms up as poor caps regain some capacitance and seem to be ok.
Buy a new set, you can send that board out and have it repaired/rebuilt but the last one I saw which was under extended warranty cost about 200 just for the board rebuild.
In the last 4 years Here on Fixya I have encountered only 2 people who were able with instructions had the skill to remove the board and replace those caps, both were top notch computer repair techs.
Dec 09, 2012 | Televison & Video
Crack my 32in sanyo hdtv lcd screen wood like to fix it for cheep
Hi ni, my name is John. Welcome to FixYa. I have fixed quit a few TV,s in my time, and this is the far best and cheapest way to do it. Get a small bottle of clear fingernail polish and lightly put it on the scratch and you will hardly notice it. Thanks for choosing FixYa... Happy holidays........John
Dec 14, 2010 | Sanyo Televison & Video
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
Sound quit while watching TV
Try to do fine tuning with all tv chanels
Sep 28, 2009 | Initial DTV-322 32 in. TV/DVD Combo
The screen looks out of focus and the top and botton bend inward.
Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Sep 26, 2009 | Sony KP-53S65 53" Rear Projection...
No picture/sound with cable
well tuners are being made smaller (and there is more cold solder in some points due to heat) so i would look up a new tuner for that tv...and if you know how to solder ,do it yourself it will be cheaper
Oct 20, 2007 | Toshiba CF32G50 32" TV
Tv tube wont stay on
in 97 Sony had problems with Flyback on these sets, so the thing I would do different is change it, along with the other components
Aug 22, 2007 | Sony KV-32V42 32" TV
Sony KP-51HW40 51" Rear Projection Television Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
