Question about Whirlpool Ultimate Care II GSW9650LW Top Load Washer
The spin cycle does not consistently start. - Whirlpool Ultimate Care II GSW9650LW Top Load Washer
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds like you may have abad lid switch, not always making contact to tel the unit the lid is closed therefore for safety resons the machine will not spn/ and or drain water.. does it seem to start when you lift and drop the lid assy after checking? you oshould hear a "click" indicating the switch is been made
Posted on Apr 23, 2010
Amana washer doesn't spin consistently.I have replaced belt and timer. Starts spin cycle and runs for about 6 to 10 seconds and shuts off.
Could be that the pump is binding which will eat belts up pretty quick, feel the belt and make sure it is not slipping and that it isn't all greasy and grimmy
Oct 09, 2016 | Amana Washing Machines
What could be the cause of loud thumping during spin?
Sounds like one of the balancing springs either broke or came off.
Feb 02, 2016 | Speed Washing Machines
Roper rab4132hq0 washer does not spin consistently. Most of the time, the spin will not engage, this isn't just for the spin cycle, but for the spinning during the wash and rinse cycles as well....
Sounds like a bad gearcase.You have a machine that is direct drive. The motor is hooked directly to the gearcase by a little coupler. Look under and make sure the coupler is in place if it is then you need gearcase.Again the coupler is located between the motor and gearcase. Hope this helped.
Jun 04, 2011 | Roper Washing Machines
Washing machine works but occasionally makes noise occasionally at end of cycle, when spinning etc. I suspect a missing sock may have found it's way through the gap and is in the drum housing, out...
Clothing cannot get into the drum housing. Noises which occur during the spin cycle suggest that the drum is being thrown of balance during the spin cycle. A possible cause of this is that the bracket which holds the drum to the spindle is partially broken. This bracket consists of 3 or 4 arms and eventually one or more arms will crack and break (this is a result of the interaction between the steel drum, aluminium bracket and electricty, which weakens aluminium over a period of time). If the machine is not examined and repaired, then the drum noise will get worse and the drum will start to knock & rub against other parts, especially the water heating element and this will result in a more costly repair.
May 19, 2011 | Washing Machines
My washer goes into spin cycle byitself and when washing,if u r in spin cycle it sets for 14 mins thats good 4 mins into spin all knob lights start flashing and the screen says uL
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
Jan 23, 2011 | Washing Machines
Too much water after was is finished
your drain pump is probably clogged or the main drian hose is kinked
Jan 12, 2010 | Kenmore 44072 Front Load Washer
Washer has started making a heck of racket during the drain/spin cycle. It's not consistant. Two loads may go thru ok no noise. A third load and it will make a very loud grinding chain like noise.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Aug 06, 2009 | Maytag Washing Machines
SPIN CYCLE DOES NOT WORK
If the motor is running and the water gets pumped out but no spin, it probably needs a thrust bearing kit, which consists of a new pully, bearing and cam.
Jun 19, 2009 | Maytag PAV2300 Top Load Washer
Whirlpool Ultimate Care II GSW9650LW Top Load Washer Logo
79 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
