Question about Minolta C250 Color Copier
In a4 copy front and rear some border line not appear.physically image shift belt have no damage
  • Minolta Master
  • 1,297 Answers
Clean the OPC drum cleaning blade assembly or change the cleaning blade and the drum,if make more 40000 copies.
Posted on Jun 05, 2010
I am getting error code sc 477 on my Ricoh Pro C901...any ideas?
Image transfer belt overrun sensor (rear) - these can become sticky as they are above the fuser - to clear the error physically move the belt towards the front of the machine away from the sensor. line up with black lines on bed of intermediate transfer blades' assembly make sure all rollers are clean and located correctly it is ok to turn the belt around to see if that helps
Apr 21, 2017 | Ricoh Office Equipment & Supplies
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
When I scan, using the ADF on my brothers mfc 6490, the resulting image is shifted, cutting off the right hand margin of the 8-1/2 x 11" scan. I am using Scansoft Paperport on my XP Pro laptop. The...
I read the whole paragraph and could not find a question, so I will try a few suggestions.
When you scan, select the option to open the scanner interface. It will give you more control on what you scan.
From the flatbed
When the scanner interface appears choose to Preview the scanned area. On the preview image click neat its border and you will see a dotted/ interrupted frame. Play with the borders of the frame to select the area. Intelligent software like Adobe Acrobat rotate the image to right it.
From the ADF
Check the alignment of the paper on the document feeder. Test the first page and see if it is correct. If it is, and all the subsequent pages have the same margins use the ADF If not, maybe you should use the flatbed.
Oct 29, 2013 | ScanSoft Nuance PaperPort 11 for PC
Can I scan legal size paper with the Canon MP 240
Hi
You can scan the largest size of paper that will fit on the glass area of the scanner (the platten).
If your legal paper fits in this area or, at least the text printed on it fits well within the borders of platten, then you can scan it.
Your scan will show you a preview of the image scanned so you can see if all the text has been scanned from the original document before you save the scanned image on the computer or copy print it.
Legal Paper Size is: 8.5" x 14" (216mm x 356mm)
A4 Paper Size is: 210mm x 297mm
Letter Paper Size is: (8.5" x 11") 216mm X 279mm
This printer's Scanning Width is: A4/Letter
This printer's Scanning Length is: A4/Letter
I hope this helps.
Aug 28, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Remove cover from HP w2408h monitor
pop the roundish 'HP' cover of the back of the stand. Remove the 4 black screws and the stand comes away. The case is just a clamshell affair, the main piece is the rear cover, the LCD front plastic border locks into it. The screen with components mounted is sitting loose in the back cover once the front border is removed. The trick is to pry off the front border without damage. Hook the fingers under the border where it lays against the LCD screen, wiggle, pull, curse and do it again. The top and bottom borders come loose easier than the end borders. Once these are popped free, stand the unit on end between your knees and pry away the end borders. A wide putty knife slipped between the border and metal frame will save your fingers but don't damage the screen. When the front border is off, lay the unit face-up on a table, undo the screws for the control panel and power switch modules, flip it over and lift off the back panel. Everything is under a metal casing.. I had no voltage from the power supply, trying to find a Fairchild chip SG6902SZ on the small control module, P/N ILTR-003, else the Pwr Bd, P/N ILP-004..
Jan 05, 2010 | HP w19 19" LCD Monitor
MY COPIER WONT COPY THE ENTIRE IMAGE, MISSING ABOUT 3/4" OF TEXT ON RIGHT HAND OF PAGES
Ensure that you do not have image shift or border erase activated.
Also many copiers will not copy 'edge to edge' as they require a void lead edge to ensure that the copy does not jam in the fuser unit and a void tail egde to ensure that the same is true when duplexing.This adjustment should be done by a qualified technician.Also make sure that your original is not larger than your copy paper as you will have to reduce the image.
Oct 10, 2009 | Sharp AL-1655CS Copier
Want to copy images from notebook paper without blue lines apparent
yes, you are loking for border erase function. when you find it then look for what looks like two peices of paper side by side, you will then possible be allowed to adust the sixe of the erased area
Apr 24, 2009 | Xerox DocuColor 12 Color Copier
The blue line appeared at the lower border of the letterbox
easy fix. adjust the vertical position of the image using the on-screen menu.
Mar 06, 2009 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Image is rotated
Select the correct paper size by rotating the green paper size selector in front of the papertray.There is two selection for A4 paper.A4 lengthwise and breadthwise.select it correctly
Aug 21, 2007 | Ricoh Aficio 2020 All-In-One Laser Printer
Minolta C250 Color Copier Logo
49 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
