Windows locks-up during start up
Windows xp locks up at windows screen and won't fully booth.
The the hard disk drive test results report # 2-07 fail. Do I have a bad hd or virus?
The computer is a HP ZE 4805us Note Book
    Scholar:
  • 67 Answers
That's a hardware report you are talking about. The drive has problems.
Posted on Mar 23, 2008
SOURCE:
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Nov 22, 2017 | Gateway MP8708 Notebook
My computer won't boot up with windows xp service pack 3
This is a strong indicator the hard drive has failed, have it tested before replacement.
Jul 10, 2012 | Toshiba Tecra Computers & Internet
Hard disk making funny noise and netbook does not recognise boot device after automatic windows update and restart.
You either have an error with your hard disk or with the Windows partition files.
Some HP Mini Netbooks have a hard drive self-test feature. In order to check for a hard drive problem, turn on your computer and press the "F10" key during startup. This will open the Setup Utility. Use the arrow keys to navigate to the "Diagnostics" menu, then highlight "Hard Disk Self Test". Let the test run fully. If it reports an error(s), then you have a damaged/defective hard drive, and you will need to replace it by either contacting HP through their support site, or by replacing the drive yourself with a new one.
If the Setup Utility cannot detect your hard drive at all, then you either have a defective hard drive /or/ a defective SATA controller (this is what connects your hard drive to the computer). Unless you can connect your hard drive to another computer, it is very hard to determine which is causing the problem. You should contact HP if you are under warranty, or check in at a local computer repair shop if you are not.
If there are no errors reported with your hard drive, then either your hard drive only fails some of the time (and you should be able to boot into Windows at the moment), or there is a problem with the partition (section) on your hard drive that handles booting up. You will need to reformat the hard drive and reinstall Windows in this case.
Mar 28, 2011 | HP Mini 1000 Netbook
My dell latitude e5400 will start up but will not load windows xp. After the dell screen comes up and the bar across the bottom of the screen becomes full it goes to a blank screen and the icon for the...
You did not post exat error ,I think Windows OS can not detect the sata hard disk.You can set up the bios for set drive sata to IDE ,or you can make the Windows cd, along with the ACHI driver for detect the sata Hard disk.
Please follow the bellow link .
http://www.raymond.cc/blog/archives/2008/01/21/install-xp-setup-did-not-find-any-hard-disk-drives-installed-in-your-computer/
OR can do another way.
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Dell Latitude E5400 Laptop
May hard disk doesn't response it says error message then when I tried to run system recovery it doesn't work too. But I'll go to windows but no display then I'll try to run hard disk self test drive the...
> hard-disk self-test drive the result is 0-7 FAILED
It's time to purchase a replacement disk-drive, and then to install Windows Vista onto it, and then connect the "old" drive as a 'SLAVE' disk-drive, to see if you can copy any files onto the "new" disk-drive.
Dec 24, 2010 | Microsoft Windows Vista Ultimate Edition
Hp invent with windows xp pro after restoring to an earlier date says windows cannot start driver corruppted?Did system Diagnostics hard disk test failed test 2 (Comprehensive)...Error: Read Failure
Restoring to an eariler date cannot fix this problem.
If the hard disk diagnostics failed, this could indicate the hard drive is about to fail. The hard disk platter/s most likely has some bad clusters and if any files are located on these bad clusters then you would get a read failure. The number of bad clusters will increase and cause further problems.
Run chkdsk to lock out these bad clusters but this is a temperoary solution and the computer may not be able to relocate the data from the bad sectors to a good sectors.
The fix is to backup your data as soon as possible, then replace the hard drive with a new hard drive and re-install Windows and the Compaq's device drivers.
Jul 22, 2010 | HP Compaq 6735s Notebook
No operating system found
just try to repair your OS if you are using windows xp. use that repair option after F8 during installation of XP.
Jan 07, 2010 | Compaq Presario Notebook
When i boot up i get a message that my hard disk failure is immenent is there anyway to repair this problem
if you get a "Disk Controller Error" error messages that may occur before Windows XP or Windows 2000 is started. Imminent Hard Disk Failure This error may appear when the hard drive detects that it will fail or stop working sometime soon.
Backup Data Before Proceeding Although the notebook may continue to start Windows after displaying the message, it is advisable that you immediately backup your personal data from the PC by copying it to a Network Drive, CD, DVD or USB storage device. After completing the backup, use one of the following methods to resolve the error. Step 1: Test the Hard Drive Use the steps below to test the hard drive in a Notebook PC using the HP Hard Drive Self Test.
  1. Plug the AC Adapter into the Notebook PC.
  2. Press and hold the Power button for 5 Seconds to turn off the PC.
  3. Press and hold the F10 key while you press the Power button to turn on the PC. Release the F10 key after text is displayed on the screen of the PC.
  4. After the BIOS Setup Utility is displayed, use the Right Arrow key to select the Tools menu.
  5. Select Hard Drive Self Test
  6. Press the Enter key to start the test.
The Hard Drive Self Test will provide an Estimated test time . A Quick test, a Comprehensive test, and a SMART test will execute when the Enter key is pressed. If any test fails , order a replacement hard drive. If all of the tests pass, the hard drive is not damaged.
If all tests pass , press the power button to restart the PC. The error was most likely a result of a shock to the PC triggering a SMART error from the Hard Drive. Since the Notebook PC passed the Hard Drive Test, it is safe to use.
Mar 07, 2009 | Acer Aspire 3680 Laptop
Will not let me Restore windows
Sounds like your hard drive is dead. If you can get to the XP recovery console with the XP cd, try running:
chkdsk /r
(it takes about 30+mins to finish) to repair the hard drive. It should work if you are able to run that. Otherwise it will tell you it failed because of the bad hard drive.
Jan 28, 2008 | Compaq Presario R3000 Notebook
Computers & Internet Logo
182 people viewed this question
Ekse
Alun Cox
