Question about Sanyo VPC-S1080 Digital Camera
Everytime i try to zoom my camera shuts off - Sanyo VPC-S1080 Digital Camera
    Scholar:
  • 56 Answers
Two possibilities here. The lens housing is damage, and when you try to zoom it is unable to do so. You would be more inclined to get a message about this as opposed to the camera powering down.
Second option is a low power situation. If you are using non rechargeable batteries, you might find they are not up to the task. I have found this with few cameras. If you are using rechargeable batteries, they may be end of life, and no longer packing the same punch that the once were.
Although rechargeable batteries have 1.2 volts instead of 1.5, they can have more power with higher capacity. I tend to use 18mAh or higher batteries in my camera, especially for zooming, but make sure to use the guidelines for charging and recharging these so they will last a long time.
Posted on Apr 23, 2010
My Kodak EasyShare M320 camera works fine except for the fact that everytime I try and zoom in, the camera shuts off. I'll charge it and the problem still doesnt resolve itself.
sounds like the zoom motor is shot. to prevent further damage, the unit shuts off when the power goes to the motor but the motor doesn't move. if power kept going it would overheat and melt inside if was allowed to get hot enough. it could be the motor is stuck but either way i think you may need to take it in to a repair shop. if still under warranty, i would take it back.
hope this helps
Apr 17, 2011 | Kodak EasyShare M320 Digital Camera
The camera turns off everytime I use the zoom button
Battery power could be getting low, and the camera shuts off because there is too much of a load on the camera when the zoom gear is operated.
Jul 29, 2010 | Kodak EasyShare Z812 IS Digital Camera
When I zoom in, the camera shuts off
Stephan, I had the same problem as this user did, I tried to zoom and it would shut off, what I did was one of your options, zoom and as I did turn the lens, like help it zoom. Now it works, thank you so much for your help! :) I thought my camera was doomed forever!
Nov 14, 2009 | Polaroid T831 Digital Camera
Won't turn on anymore
this is an extrememly common problem with the camera's firmware. The system needs to be updated. Kodak will repair it for $50. ALso sometime wiggling the zoom/lens will help open up camera.
Jul 07, 2009 | Kodak EasyShare C653 Digital Camera
Zoom drains the battery
Common problem.
Zoom motor got bad. Can't move lens.
Needs replacement.
Apr 02, 2009 | Olympus Camedia C-700 Ultra Zoom Digital...
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Will not zoom
its broken mine dose the same
May 19, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Zoom
Hey bello205,
This camera does not allow the user to actually turn off the optical zoom, but does allow the user to shut off the digital zoom. If you are talking about the digital zoom make sure it is turned on in through the menu system. As far as the optical zoom goes make sure you are not in playback mode. If this doesn't work you can try having the camera reset to the original settings every time you shut off the camera by choosing this option under the setup menu in playback mode. If none of this works have the camera looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
May 01, 2008 | Olympus Camedia C-720 Ultra Zoom Digital...
Kodak V603 Zoom Problem
I have the same problem... when I try to operate zoom, camera shuts down. Help!
Aug 09, 2007 | Kodak EasyShare V603 Digital Camera
Zoom and the camera shuts down
lo m8 sounds like a software problem m8 but cant be sure without taking it apart i would look for any damage to lense or switch for zoom.if no fault is found then i would try and find the software for it. but if you want more info or would like to get it done from somewear then try tech sapport at this site http://www.mobilephoneservicecentre.co.uk/
Feb 27, 2007 | BenQ DC E600 Digital Camera
Sanyo VPC-S1080 Digital Camera Logo
53 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
