Question about HP DeskJet 895cxi InkJet Printer
Green light and middle red light flashing will not print out
4 Suggested Answers
SOURCE: printer won't print
I've had this 6110xi all-in-one for a few years now. Everytime I have the "no-printing" issue I need to unplug the printer, and leave it unplugged overnight. The problem magically goes away in the morning.
I've installed the printer on a separate computer while it was having a "no-printing" episode and still couldn't print there either. So it sounds like there's something funky with the printer internal cache requiring a long power-down.
Posted on Feb 08, 2008
Joed911
  • 4338 Answers
SOURCE: deskjet 940c
Shut down the PC. Pull the AC power cord from the printer out of the wall. Wait 30 secs. then plug the printer back in, then power up the PC, It should go back to normal.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 04, 2008
57 varieties
  • 1653 Answers
SOURCE: HP 6540 Lights flashing can't print
This indicates a paper jam or the printer is out of paper. Do not clear a paper jam from the front of the printer.
The printer might be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of the printer.
There might be a paper jam
1. Press the Resume button. If the paper jam does not clear, then go to the next step.
2. Push the two latch handles on the rear access door toward each other, and then remove the door.
3. Remove any paper that is inside the printer by pulling it out from the back of the printer. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
4. Replace the rear access door.
5. Press the Resume button.
If the Two-Sided Printing Accessory is attached to the printer, follow these steps to clear a paper jam from the Two-Sided Printing Accessory.
1. Turn off the printer.
2. Press the buttons on the left and right sides of the duplexer, and then remove it from the printer.
3. Remove any paper inside the printer.
4. Open the duplexer.
5. Remove any paper from inside the duplexer.
6. Close the duplexer, and then re-attach the duplexer to the printer.
If the Auto Two-Sided Print Accessory with Small Paper Tray is attached to the printer, follow these steps to clear a paper jam
2. Press the buttons on the left and right sides of the accessory, and then remove it from the printer.
3. Remove any paper that is inside the printer.
4. Lift the back lever on the accessory, and then unhook the Small Paper Tray
5. Tilt the Small Paper Tray forward and open the lower door of the accessory.
1. Tilt the Small Paper Tray
2. Open the lower door
6. Remove any paper that is inside the accessory.
7. Close the accessory, and then secure the back lever to close the accessory.
8. Re-attach the accessory to the printer.
Posted on Oct 03, 2009
Two red flashing lights on top and two green on bottom
Two red lights generally indicate hardware failure. Two green lights indicate two controllers are connected. Both green and red lights will not be lit at the same time. The green light in the middle indicates that the console is turned on. For more help deciphering red light flashing errors, see this guide HERE.
Feb 02, 2011 | Microsoft Xbox 360 Console
Paper stops half way
Please check for torn piece in the carriage which is causing the error
Jul 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Lights flashing, printer won't print as a result of a paper jam
Hi Girlemom. Just had the same problem here. Lift up the lid and slide the ink cartridges to the left. If they are stuck in the middle, this will prevent the printer from starting properly. Then, unplug it, plug back in, and turn on. It should restart normally.
May 08, 2009 | HP DeskJet 5550 InkJet Printer
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Lights on printer are alternating between red and green flash
try to reset the printer by opeing the front cover and close it again.
Mar 17, 2009 | Samsung ML-2510 Laser Printer
HP DeskJet 895cxi InkJet Printer Logo
Seeker5211
Seeker5211
