Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Akai 55 I have ghosting (mostly red) on my Akai 55" Projection TV, Model Number PT5598HD. The red is out of whack. I tried manual fix on the convergence and can''t get it straight. I have tried the direction in the users manuel, but the red doesn't move enough to line up. How can I fix this? Please help!
  • 1 more comment
  • hiker2158 Mar 26, 2008
    I have the same problem. I have tried to adjust from inside but no matter what I do there is always a bluer. I believe if the colors would aline it would be OK.
    It is the worst at the bottom, you can hardly rear the text.
  • Gimpy03 Apr 02, 2008
    I have the same problem. I used the "mute, 1, 8, 3" with the power on. I was able to line up the blue and the green grids, but the red grid will only adjust up and down. I need it to move left. I currently have a gap of almost 3 inches on the left side. If any one can help, I would appreciate it greatly!
  • medievalvill Jan 21, 2009
    Normal 0 MicrosoftInternetExplorer4
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}I have the same symptom; I tried both codes, but no luck. Inaddition I was unable to merge any color bars to align. It appears the pictureis bowed, I tried the bowed setting and a few other but o luck. Any body haveany other tricks for this problem?
    Thanks for listening.
This same problem just started on our TV this weekend. Did the Mute 183 thing, got the lines to align (kind of), but there is no "enter" button on the remote. maybe remotes are a little different. Where is "enter" button?
Posted on Mar 31, 2008
I used" Silerado 1st" solution. I have an Akai pt5598hdix/sms.
I had ghosting.Like 3 colors side by side.
Silerado said with TV off press "mute,1,8,2" then TV on.
I didn't see anything like a menu.He warned to write down any setting you saw before you change anything.But for me nothing came up. So as he said the next step try with TV "on" press "Mute,1,8,3" this is another set of adjustments for finer detail. I lined/overlapped all the lines up or down or side to side useing the channel and the volume buttons and then held the enter button down until the TV flashed 3 times.Then I shut it off and when I turned it back on It was perfect.
Thomas Fitzgibbon
Posted on Mar 30, 2008
Akai PT5598HD 55 in. Rear Projection HDTV-Ready Television tv looks like it is now 3d model with red out by about a half inch. will not adjust on converage settings
sounds like your convergence board has failed ...there may be a kit at tvrepairparts.com..there you can search your model number for a convergence repair kit...you will need to have someone with electronics repair experience install the parts if you do not know how yourself...these kits range from 40.00 to 100.00 and usually come with a cd or dvd to aide in installing these components.
Dec 20, 2010 | Akai PT5598HD 55" Rear Projection...
AKAI PT5598HD will not turn on.
if you got to the following link and search by the model number you will find what your looking for.
Http://www.samsungparts.com/search/search.asp
The part number for the service manual is SM-PT5598HD
As the set is showing a blinking red timer light. you can check the following link out.
http://www.techlore.com/article/15444/
May 13, 2008 | Akai PT5598HD 55" Rear Projection...
I have an akai 55" projection tv and the top and bottom of the picture is bowed with green and red colors which makes it look like a 3-D movie. how can i fix this problem and what will it cost to fix and...
The tv have a problems known as a convergence problems,it dead.Yes,try website like Tvrepairworld.com to buy a whole rebuild convergence board for the replacement.The Akai/Samsung use the same tv convergence board.The board around $200.
Sep 09, 2010 | Akai PT5598HD 55" Rear Projection...
Akai rear projection tv...picture is not deformed....however there are images (Ghost image) in separated colors...like 3d
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 24, 2010 | Akai PT5598HD 55" Rear Projection...
My Akai TV Model number PT5598HD shows two of everything, how do I fix this?
U can't.Ur convergence is dead.Try website Tv repair World.com to buy a Convergence board to replaced.Well solved the convergence problems.The Samsung/Akai use the same convergence board.
Feb 15, 2010 | Akai PT5598HD 55" Rear Projection...
I am not able to use the blue and red convergence feature on my Akai Projection Television. Is there a solution to this problem? Thank you
Yes,convergence is dead ics and resister must be replace.U know how to solder right?Tries websites for convergence kit.Tv Repair World.com or Ebay.com.
Oct 05, 2009 | Akai PT5598HD 55" Rear Projection...
AKAI PT5598HDIX, the picture is ghosting
Convergence - many other posts here. A sample: http://www.fixya.com/support/t634294-replaced_convergence_board_picture_still
May 01, 2009 | Akai PT5598HD 55" Rear Projection...
Akai projection tv ghosting
You need a professional.
Stop using the TV until it is repaired.
Continue to use it and your problems will multiply and grow more expensive.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Akai PT5598HD 55" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Describe your Akai PT5598HD 55 in.
looks like you have a convergance problem akai is made from samsung
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 17, 2007 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
311 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
