Question about Samsung SyncMaster 920NW Monitor
Hi, my SyncMaster 920nw turned off today, when I turned it on the colours were changed, all desktop went in transparent green and I can't make colours back to normal, I pressed the auto button and desktop became a little bit darker but still colours aren't normal, what could be wrong?
    Scholar:
  • 56 Answers
Don't shoot me for this, but have you checked that the cable is plugged in tight on both ends. This kind of color change happens when a cable is not seated correctly.
You might also check that the pins on both ends of the cable are not damaged or bent.
Posted on Apr 23, 2010
  • 661 Answers
Well a few things could be wrong. In my shop I could tell you pretty quick which it was. But lets look at the possibilities.
1. Monitor has gone bad.
2. Somehow the monitor has become partially disconnected from the PC on one end or the other.
3. The video card has gone bad.
First check that the cable is plugged in to the PC and the monitor securely.
If that doesn't fix the problem check it with another monitor. Borrow one if you have to. If that fixes the problem then you know your monitor gave up.
If it doesn't fix the problem then your video card is bad.
I have samsung sync master 920nw monitor . this monitor turn on after few minutes disply is going turn off ,but power butten LED working...I romove the PCB and changing All capacitor but no use ..same
The back light tubes are probably exhausted. They can be replaced, or you could try a CCFL to LED back light conversion. eBay.com has some kits for doing that.
Apr 23, 2014 | Samsung SyncMaster 920NW Monitor
Green and red screen on Samsung SyncMaster 920nw
Replace the video cable or hdmi,depending on which you may be using. Some of the small wires in that cable may have snapped. Another suggestion is to take it into a repair shop that gives free examinations or diagnosis, because one of the small leads going from the screen to circuit boards lining the display, may have broke, unfortunatelly this may lead to you having to buy a new display. Most of the time it can not be reconnected due to many wires in the same ribbon are to close. You may also have to purchase a new screen from the factory.
Feb 07, 2013 | Samsung SyncMaster 920NW Monitor
Hi I Got a Samsung SyncMaster 920NW the display
If you are saying that it powers off in a few seconds you most probably have a bad (internal) power supply.
Jul 12, 2010 | Samsung SyncMaster 920NW Monitor
Dark screen samsung syncmaster 920 N strange noise behind it
The clicking sound you hear is the power supply board trying to start up, this indicates the board has failed. This is a common problem with all LCD monitors after a few years of use. Parts called capacitors on the power supply board fail and they will keep the power supply from starting up correctly. If you can solder then you can repair the board yourself. Here is a link to a repair guide with pictures and videos showing how to dis-assemble the unit and then what to look for and replace to rebuild the board and get the unit back running.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Dec 19, 2009 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920nw suddenly went black now squeaks/flickers
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
The repair guide has pictures and videos to guide you through the repair.
BuddyMc
Nov 14, 2009 | Samsung SyncMaster 920NW Monitor
My samsung syncmaster won't start. It stays black (the light on the power on button is green). If I try to power it off and on again, I can see my desktop for a few seconds then it beeps and die.
Hi:
You have a problem with the power supply that is built into the monitor. These are not easily repaired, as the cost exceeds the value of the monitor.
Nov 04, 2009 | Samsung SyncMaster 920NW Monitor
My screan has lost white colour and now it displays pink colour.
check your video cable....this is a common problem when a certain pin in the connector is loose
Aug 16, 2009 | Samsung SyncMaster 920NW Monitor
Added as 2nd monitor, color PINK
Check the cable...are any of the pins damaged, bent or missing? Can you access the Monitors control panel and reset its settings to factory default?
May 17, 2009 | Samsung SyncMaster 920NW Monitor
Samsung SyncMaster 920NW Monitor Logo
167 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
