Question about Brother MFC-9440CN Laser Printer
Can you reset the cartridges after is says replace?
How do I reset the chip on my ink cartridge for a epson wf 2540?
You're better off buying the auto reset replacement cartridges. Word of warning: Epson printers "SPY" on you and tell you that by putting in the compatibles, you will void their warranty. Second Warning: DO NOT download any Epson firmware upgrades because they will wipe the compatible chips and render them unusable. Always keep your old, used epson cartridges in case you need to reset the printer with the original chips.
Feb 14, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Hi, I have a Workcenter XD102. It gives me a J2 error. I don't know how to fix it. Please help. Thank you very much, Charles
J2 error for Workcenter XD102 indicates a Drum Cartridge Problem sensed by the main PWB indicating that the Drum cartridge had reached its end of life. You may replace the Drum cartridge with a brand new Drum Cartridge. This should fix the problem.
If you believe that its not the Drum cartridge with or without replacing the Drum cartridge, you may try to open the printer, make a good clean and perform the below. 1. Check the PWB and Drum Cartridge Reset Circuit for any loose connection and short circuit. You may re-seat the cables and terminations and test. 2. If that didn't work you might need to get some voltage from the Drum Cartridge Reset Circuit as per below. 2a. If voltage is more than 0.5 VDC measured between PJ CN116-2 and GND then you need to replace the Drum Cartridge Reset Switch PL x.x. 2b. If voltage is less than 0.5 VDC measured between PJ CN116-2 and GND then actuate the Drum cartridge Reset Switch. Then check the voltage if its +5 VDC measured between PJ CN116-2 and GND. i. If not then replace the Drum Cartridge Reset Switch PL 5.. ii. Else it should be fine. iii. If not then replace the Main PWB, PL 7.1.
Jul 12, 2011 | Xerox WorkCentre XD102 Printer
I have replaced black ink cartridge 73N message on screen says Error i press ok to proceed message goes back saying replace ink cartridge?
The main problem in using the latest Epson printers, is the ink replacements. Ink cartridges like 73N has its own ink reseter (the little chip in front of the cartridge). Once you replaced the ink without using the right procedures, for example you have a 10% remaining ink level on one of the cartridge, and you replaced it without using the setup menu and selecting the replace ink cartridge, even though the cartridge is new, the printer will read the replaced cartridge as a 10% ink level cartridge. When the remaining 10%, drops to 0%, your cartridge will read as an empty cartridge. The chip on the cartridge is registered as an empty cartridge.
-try to replace the ink reseter or try to clean the cartridge chip then put back the ink.
Mar 23, 2011 | Epson Stylus TX400 Series
Epson Stylus TX400. Refuses to accept either compatable or refilled cartridges?
Epson TX400 is so sensitive in terms of ink cartridges, you can only replace a refilled ink cartridge in this type of printer if the cartridge has an automatic ink reseter chip. When you replace a cartridge in your printer, it will automatically register the ink level in the chip. So you need an ink reseter chip to replace a new refilled cartridge.
Feb 17, 2011 | Epson Stylus TX400 Series
How to reset ink level canon iP 2772??
Download and run the ipTool to reset your ink level :
http://www.mediafire.com/?nmj5nnzzjaw
Features IP Tool software:
  • Showing all info on the printer such as ink level, ink counter number of cleaning, cartridge replacement and more.
  • Print test feature to test nozzle on the cartridge.
  • Cleaning and deep cleaning feature to clean head cartridge and cleaning the rollers.
  • Changing the delay value for drying.
  • Set the printer model manually.
  • Reading and reset EEPROM printer.
  • Reset counter and reset ink level on the color and black cartridges.
Ink Level - shows the level ink:
  • BK - black cartridge.
  • CY - Cyan cartridge.
  • MG - Magenta cartridge.
  • YL - Yellow cartridge.
  • WM - Waste ink counter status.
  • WP - "additional" waste ink counter status.
Port Name - displays the port where the printer installed.
Port S / N - shows the serial number of the printer port.
Power - shows the number of:
  • ON - inclusions printer.
  • OFF - to turn off the printer.
Cartridge Info - Displays information status of:
  • CL - colored cartridge.
Head Parking - displays the number of parking.
Head Cleaning - shows the number how many time the cartridge cleaned.
Head Deep Cleaning - displays the number of deep cleaning Printer cartridge.
Cartridge Replacement - shows the number of cartridge replacements:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 20, 2010 | Office Equipment & Supplies
Reset the ink memory level after replacing cartridge
Have you tried to unplug your printer and plug it back in?
May 31, 2009 | Dell 962 Photo All-In-One InkJet Printer
Refilled cartridge, still says it needs to be replaced...
If you let the cartridge run totally dry then they need to be reset or replaced, I have tried purchasing reset software myself and found then to be a waist of money as they do not reset the cartridge at all. Do yourself a favor and replace the cartridge and remember to top up the cartridges before they get half empty.
May 08, 2009 | Lexmark X2600 InkJet Printer
J2 drum cartridge light no after replacing drum
J2 is the indication that the Drum Cartridge life has elapsed. The possibly exists that the Customer has installed a New Drum Cartridge. The Customer would be directed to change their Drum Cartridge by their User Guide. This action on the part of the Customer will cause the Drum Reset Switch to actuate for a moment when the Side Door is closed. This is with the provision that the Drum Reset Circuit is working properly. That momentary actuation of the Drum Reset Switch, being actuated by the New Drum, resets the Drum Counter. Should something be faulty with either the reset mechanism on the New Drum Cartridge, or the Drum Cartridge reset Switch circuit, the Counter will not reset. Note: A new Drum Cartridge will NOT reset the Drum Counter unless the machine is holding a J2 presenton the display. The first revolution of the Drum will render the Drum Cartridge used. A Used Drum Cartridge will NOT be capable of resetting a J2. Again, one revolution of a new Drum Cartridge will render it to be a used Drum . Cause:
Apr 25, 2008 | Xerox WorkCentre XD130DF Laser Printer
Brother MFC-9440CN Laser Printer Logo
26 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
