Question about Kodak EASYSHARE 5100 All-In-One Printer
Why wont my printer print e-mail? Just date and page number show.
How many pages in a pdf download for Necchi Instruction manual for Necchi Model 3101 FA?
when the down load opens up on the screen, in a small tool bar at the top of the pdf section there are areas that show page numbers , zoom in / out expand size etc the number of pages will be there shown as 1 /24, or 50,or 600 etc ( 1 / of the number of pages in the down load )
if you click on the scroll bar on the right of the page proper and scroll down , as you pass each page break it shows the next page number
if you scroll down the page you will come to a contents list and that will also show the number of sections in the manual and that will indicate how many pages you can expect
to reduce paper wastage from a normal house hold printer when you print from the printer logo in the bottom right of the page you get the printer up and where it says print all , change that to print odd pages ( or even pages ) or or print pages and this is where you put in the pages that you want printed -such as 1,3 5, 7 etc
when the print run is finished put the whole lot of printed pages turned around and back in the printer then print the page numbers that you missed on the first print run this will result in a booklet with printing on both sides of the page and reduce the number of sheets used in printing
Nov 07, 2015 | Necchi Sewing Machines
How to remove the date and page number from printed sheets
If you are referring to a page number that is appearing on printed documents then you will have to look at the software you are using. If it is a premade document like an PDF file you would need a program capable of editing a PDF. If you are referring to the date and page number on a fax you likely cannot delete that.
Jun 05, 2015 | Brother MFC-7340 All-In-One Laser Printer
My new ricoh aficio sp 100su ddst printer has hardly printed 100 pages and now it show E7 and doesn't print. what must I do?
Go to page setting option and set page range and page auto print. If printer ok then may be E7 browser not full support so that up to date then you try.
Read More Help... Ricoh SP 100 Printer Need to press Form Feed button every time to print... and Ricoh Printer Support
Thanks,
Sep 10, 2014 | Office Equipment & Supplies
Will this camera put the date the picture was taken on to the actual picture? I know it shows it on the screen but can it be printed too?
This camera will not deface your images by scrawling a string of numbers across them. If you're printing directly from the camera to a PictBridge-compatible printer, you can tell the camera to print the date on the pictures by setting the Date option to "Date" or "Date&Time". Refer to the "Printing images directly using a PictBridge Compliant Printer" section of the manual (page 86 in my copy).
Mar 31, 2011 | Cameras
Whenever I print from there is an extra page that prints after that includes: Filename: Directory: Template: Title: Author: Keywords: Comments: Creation Date: Change Number: Last Saved on: Last...
when you go to "print" a box should open asking if you want to print "all" or "pages" . click on "page" and then click "1" then you wont get the trailing page.
Feb 21, 2011 | HP LaserJet 4200n Printer
How to print a fax confirmation?
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
Jan 26, 2011 | Konica Minolta Minolta FAX3900 Digital...
Our printer PIXMA mp800 -serial #aadn07652 will not print out entire page of e-mail. It does print out From/Subject/Date/To//attachments included And a short three line note with a second short paragraph...
Hi,  I thought that I answered the question in the original contact. Yes, the problem was solved and I am happy with the result. I am the owner of an iMAC - APPLE computer and I do not have 'Word' or 'Note Pad' in my system preferences and that caused some delay in reaching the solution.   The incoming e-mail was to blame. Thank You, Mary-Ann Peckler (Sandymap)
Aug 28, 2008 | Canon Office Equipment & Supplies
Number of pages my printer has printed
You need to print a self diagnostic page. On that page will be listed the number of pages printed from trays and accessories.
To print the Self-Test Diagnostic Page
• Control panel: Press Setup, select Print Report, select Self-Test Report, and
then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print Self-test
Diagnostic Page.
• HP Printer Utility (Mac OS): Click Device Information from the Information and
Support panel, and then click Print Configuration Page.
Thanks and please take a moment to rate this as fixya.
Jul 06, 2008 | HP Officejet Pro L7680 All-In-One Printer
Prints an extra sheet with specs on font, characters ....
click the printer button (shown above) and in the menu there will be an option to print banner page.
please turn this off
that should fix your problem.
May 08, 2008 | Copystar CS-2030 Copier
HP 1320 PCL
check the printer driver properties settings. look under printing preferences and check the settings there.
May 07, 2007 | HP LaserJet 1320 Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
16 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
