Question about GPX D715 Clock Radio
I need to set it to play a cd for 45 minutes and then turn it off
  • GPX Master
  • 13,433 Answers
Hello and welcome to FixYa. Please send me the brand and model of your _____ ? and I will look into it.
Posted on Apr 23, 2010
CD player works but start delays from 5 minutes to 20 minutes. What could cause that?
Dust inside the cd player could be causing problems.
You need to try playing a cleaning cd and follow the instructions that come with it. You can also spray compressed air to clean out the cd portion of the stereo. You can also try unplugging the unit for 20 minutes and then plug it back in. Make sure your cds are clean and not too scratched up. If the unit is under a year old it may still be under warranty. If this does not resolve the issue you may have to have the unit professionally repaired. If the unit is not worth repairing you may need to buy another unit.
Nov 02, 2015 | JVC UX-T3 Shelf System
OMT Jukebox plays tracks continuously but will play selected track when ordered. Have turned off continous play button but it continues to play. Have programmed it not to play but it continues to play.
Perhaps someone has programmed the machine for "Play stimulator" (random play) or background music. The easiest way clear all f is to default the machine to factory settings. First, unplug the memory plug (red wire at bottom right side of selection and computer and turn off power to the machine for 10 minutes with the memory plug unplugged. After turning on power, the carousel will rotate to determine its capacity. After that the machine is ready for operation. Re-connect the memory plug. If you need further help you can contact me, tech@wurlitzer-ohio.com
Jan 20, 2011 | Wurlitzer Jukebox 1015 One More Time...
Yesterday after playing video games for a couple of hours my son tunrs off the set. He returns 45 minutes later turns the set on as usual the green power light flashes 3 times followed by a red indicator...
Red flashing 6x is a thermal fuse,I have serviced hundreds of these models and have never encountered 7x.If it is flashing 7x try unplugging the power for 2-3 hours and try it again.If that doesn't work you will need probably need a K-board.
Nov 10, 2009 | Sony KDS-R50XBR1 50" HDTV
Plays a/v for a min, turns off standby light blinks 45 times
If you have never replaced the lamp before its likely to be close to the end of its usable life. best to replace it, the ballast in the tv can be damaged by your lamp and then you really will have to get out the wallet. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
Timing of Mastering and burning final copy to CD
I don't use my Tascam to create CDs for exactly the reasons you are asking about. I do a bounce mix to a couple of tracks and then export via usb to a PC for finalizing and CD creation there.
To answer your questions, you do always need to create a master first for each sermon on the DP-02 before you can burn it to a CD. You also have to finalize the CD to play it on other players.
Mastering as well occurs in real time, so it does take 60 minutes to create a master for a 60 minute recording.
As I don't burn from my Tascam, I didn't realize the burn time was so long though. I would have expected that to be faster for sure. I know my old 2488 MkI is supposed to burn at 4x and I believe the MkII burns at 8x. The DP-02 is newer than both and I would assume it would burn even faster.
Anyway, as I said you might wish to go the PC route. That way you can export the tracks without having to master them and burn them from the PC to CD at up to 40x (depending on the speed of your PC's burner).
Hope this helps.
bd.
Jan 06, 2009 | Tascam DP01 All-In-One Recording Package...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Wurlitzer 2500 jukebox
You don't give enough information. Is it in the play position? Is it putting the tone arm down on the record?
Mar 26, 2008 | Wurlitzer Jukebox 1015 One More Time...
My wurlitzer jukebox 45 turning but not playing
What's turning? The carousel or the turn table? I need a better description of the fault.
GPX D715 Clock Radio Logo
47 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
