Question about Rockford Fosgate Punch Stage P110 S4 Car Subwoofer
Static Interference With Subs
Im having a problem with my subs. everytime i turn on my car my subs will start buzzing only when the car is on. when i turn the lights on to my car the buzzing won't be as bad. im not sure what it is anymore. i've moved my rca cable as far away from and other electrical wire too keep the rca cable from picking up interefrence from any wire but it still buzzes. Would you know of anything that could cause this static interference? if so, how do i fix it?
    Sergeant:
  • 300 Answers
First test would be to disconnect the RCAs from the amp and see if the buzzing goes away. If it does, the issue is either with the head unit or noise still being picked up on the RCA cables. If the issue stays, it's possible your electrical system has not a nice and clean 12V. You might have to get your alternator and voltage regulator (if so equipped) checked.
Also, make sure the RCAs on the back of the head unit aren't touching anything metal. Set your gain to 50% and see if the buzzing changes. Check your ground connection and make sure it's short, clean, and solid. If you have multiple amps, ground them to the same point.
Posted on Mar 27, 2008
Subwoofer making static noise
first of all,do u have the strip wire in the red which is the hot side of the sub,next if that doesn't fix it u need to change ur spark plugs they will interfere when the engine is running,so call ur local auto parts dealer and ask for spark plugs that don't interfere with the radio.Hope this helps
Apr 03, 2013 | Power Acoustik Car Audio & Video
My sub ts7 won't power on
check the cable , might be it burned bcoz of the voltage fluctations.
If not check the transformer if its buzzing or not. if not- buzzing replace the power cord
Aug 08, 2012 | Harman Kardon HKTS 7 System
I have two audiobahn aw1206t 12in. subs in a box hooked to a 100.1 american bass amp its 1000 watt mono block. i also ran a capacitor due to my lights dimming. but for some reason my amp keeps kicking over...
This could be caused due to the impedance load being to low. Your amp is stable to 2 ohm load however its very possible that you have your subs wired to a 1 ohm load that would cause the amp to go into protect mode. The subs you have are dual 4 ohm voice coils and would need to be wired in series/parallel. I've included a link that will show you how the subs should be wired.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
May 16, 2011 | AudioBahn AW1206T Car Subwoofer
Just bought 2 12 in d3 dual 2 ohm subs with d5 600.4 amp. Need to know how to wire subs. They were in a box already I assumed they were wire at 2 o When i hooked One up to my amp it hit really for Jus...
what wattage are the subs and amp? if your subs are more wattage than your amp, your amp will blow fuses as cant handle the output to your subs. for example. you have 2 500 watt subs and a 300 watt amp, that is no good as amp isnt powerful enough. if you have 2 500 watt subs you need at least a 1200 watt amp to power them both. 200 watt more than the combined wattage of subs as amps should never be turned up to max as they tend to blow and overheat more quickly. 80% volume on amps is reccomended by installers and manufactures.
Feb 27, 2011 | Diamond Audio D5-600.4 Car Audio Amplifier
A2200 htc wont bump my subs and the fans never turn off
check your wiring's, there are two positive lines, one is directly connected to the batteries positive terminal and the remote positive is connected to the ignition's positive, and make sure it is properly grounded.
Jun 10, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Rockford Fosgate Punch Stage P110 S4 Car Subwoofer Logo
195 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
