Question about Peripheral Enhancements Peripheral Gmh32t Cd Changer Interface Adapter 1995 01 Buick Oldsmobile Vehicles To Gmasx "T" Harness
01 buick engine 3800 runs fine has code p0452 an code p0102 what should i look for
  • 524 Answers
The p0452 code means Evaporative Emission Control System Pressure Sensor Low Input. This means that you may have problems with the fuel system. Is the car running? The p0102 code is for mass air flow low voltage. Hope this helps
Posted on Apr 23, 2010
  • Alex May 08, 2010
    can i ask why i only got 2 thumbs up.... i answered all your questions to the T. Is there anything else that i may assist you with so you are a happy customer
Hard to start when hot
This can be a problem with your starter so better check the starter or have it replace...
Hope that helps........
Jul 26, 2008 | 2001 Buick Regal
My 2000 Buick Lesabra 3800 has a ticking noise coming from under the hood what could it be..not leaking oil or any fluids...checked oil and it's fine
If only when engine is running, probably valve tappet noise. How many miles on engine? How often do you change oil and filter?
Apr 29, 2015 | Buick Cars & Trucks
2003 Buick 3800 engine 82,000 actual miles on it multiple/random misfire code How it started.. Car was running fine. Check engine light started flashing and engine started missing. What...
You can't rule anything out yet. It could be a plug or injector among other things, but probably not low fuel pressure. If you have a code 300 and nothing else, you may have to wait until the problem gets bad enough to set additional codes. And if any of the sensors fail, such as the cam or crank sensors, you'll get a code for those to be tested.
Have the plugs been checked or replaced in the past 30,000 miles ?
Mar 12, 2014 | 2003 Buick LeSabre
My 01 Buick regal with supercharged 3800 won't
it flooded. step on the gas pedal fully and crank the engine; that forces it to go into a clear flood mode by turning off the injectors. it may take a little while, but it will start.
Apr 08, 2013 | Cars & Trucks
I have a p0300 code the car runs fine I clear the code changed plugs and wires and the code keeps on coming back
For OBD code problems check the list of help links below. Click the link below to go through its procedure.--------------Diagnostic Code P2195?http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html--------------Diagnostic code P1330?http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html------------Diagnostic code P0700, P1330, P1121?http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html-------------shows error code P1330?http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html--------OBD code P1330?http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html------------OBD code P01300?http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html--------------OBD code P0768?http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html------------Evaporative Emissions System codes details?http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html--------------- Engine Misfire codes?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010?http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html-------------Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error Codes?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.------
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540 continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
-----------This will help.Thanks.
Feb 13, 2012 | 1998 Plymouth Neon
1996 3800 non turbo number one cylinder misfire code P0301
For engine misfiring problem check the help links mentioned below. Click the link below to go through the troubleshooting procedure :---- OBD-II Trouble Code P0300? http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
-------- Engine misses and truck jumps? Hard to down shift? Issue with high gear only? http://technoanswers.blogspot.in/2012/02/engine-miss-and-truck-jumps-hard-to.html
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
Engine Misfire codes for car?
Oil on spark plugs and car misfires?
http://technoanswers.blogspot.in/2012/02/oil-on-spark-plugs-and-car-misfires.html
This will help.
Thanks.
Jan 22, 2012 | 1996 Buick Riviera
We have a 95 buick riviera with the supercharge 3800 v6 engine. It overheated, usually runs at 200 degrees and blew the oil dipstick up and oil splattered on the engine. Oil level is ok and oil...
The overheating might be caused by a thermostat stuck closed, have it replaced. That should fix the overheating, as for the hesitating, run a scan on the ECM module to make sure you dont have any codes, clear if any and fix anything that might've gotten damaged from the overheating.
Aug 23, 2011 | 1995 Buick Riviera
Check engine light comes on intermittently,
the 1st thing u need to do is have the system computer tested for trouble codes, anytime the light comes on a trouble code is stored, there are over 200 of these codes for potential system malfunctions, yours sounds like a O2 problem.
Jun 10, 2009 | 2001 Buick Regal
2002 chevy impla v6 esngine 3800 check engine light is on, codes read po102 what does this mean
Code p0102, on either the 3.4 or 3.8 (3800) v6 engine is a problem in the Mass Air Flow sensor (MAF). If any work has been done to it just prior to this code, then you need to make sure the air cleaner, duct work, breather tubes, etc. are properly connected and not loose. If that is OK, then may have a bad, or dirty sensor.
Tech JK
Dec 20, 2008 | 2006 Chevrolet Impala
Peripheral Enhancements Peripheral Gmh32t Cd Changer Interface Adapter 1995 01 Buick  Oldsmobile Vehicles To Gmasx "T" Harness Logo
554 people viewed this question
Top Peripheral Enhancements Car Audio & Video Experts
xxxxxx xxx
Are you a Peripheral Enhancements Car Audio and Video Expert? Answer questions, earn points and help others
