Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I just put the mower deck back on my 18 HP 42" craftsman tractor & the blades won't engage. The belt is not spinning.
  • kbrev11 Apr 23, 2010
    The belt is not old or worn & it's around all 3 pulleys. I've lowered the blade to it's lowest level & it still does not engage.
    There's a clutch spring, but I don't see an idler pulley spring
    Genius:
  • 1,400 Answers
Hello
There should be 3 pulleys for the blade belt.Two on the deck and one on the engine.
Is the belt on all 3 pulleys? Also is the belt worn or old?
Check your engage lever and be sure its dropping the deck down far enough to put pressure on the blade drive belt.
Posted on Apr 23, 2010
  • mpcheesman1
    mpcheesman1 Apr 23, 2010
    Is there a idler pulley spring?
Got a craftsman mower 42 inch deck changed spindles and blades and deck still shakes belt may not be tightening up
did you put the blades on right ??? they have a star pattern and it needs to be lined up correctly... if that's ok does the belt have a bad spot in it or is the engagement mechanism operating correctly ???
Oct 20, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20hp lawn tractor blades won't engage
check to make sure your cable is in tact its called a pto clutch cable about 20 buck on ebay it may be broke inside
Sep 26, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
The blades do not spin when put into gear
Look to see if the belt has come off the deck. Also, does the handle that engages the blades have tension on it or is it loose?
Oct 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
May 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42" Tractor Blade Problem
sounds like either the spindal bearings are shot or maybe the spindal shaft is bent. check for up and down slop at the blades. then turn blades towards each other and check that the heigth lines up. also chec the idler pully to make sure it is not slapping around.
Aug 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
42 inch Craftsman blades won't engage
model 917258862 mower was given to me. sat outside numerous years. I've managed to get it to start run and drive, but cant get blades to engage. don't know what the wires are for or do that go to some sort of pulley attached to the bottom of motor. can somebody help me pls ?
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
163 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
